Calculating Distance Traveled: Const., Time, and Dist. Dependent
  • Context: Undergrad
  • Thread starter Thread starter cask1
    Distance traveled Time
The discussion focuses on calculating distance traveled based on varying speed conditions. When speed is constant, distance is calculated using multiplication. If speed depends on time, integration is required, while speed that varies with distance necessitates the use of differential equations. It is noted that in all scenarios, solving differential equations involves integration, highlighting the interconnectedness of these mathematical concepts.
  • Understanding of basic physics concepts related to motion
  • Familiarity with mathematical operations such as multiplication and integration
  • Knowledge of differential equations and their applications
  • Ability to interpret and solve mathematical problems involving variable rates
  • Study the principles of constant speed and its mathematical representation
  • Learn about integration techniques and their applications in physics
  • Explore differential equations and their role in modeling dynamic systems
  • Investigate real-world applications of these concepts in physics and engineering
Students of physics, mathematicians, and anyone interested in understanding the mathematical foundations of motion and distance calculations.
cask1
Is it correct to say that following?
To calculate the distance traveled from the origin after 1 hr when the speed:
a) is a constant. Use multiplication.
b) depends on time. Use intergration.
c) depends on distance from the starting point. Use differential equations.
Welcome to physics forums.
I suppose you could say that. However, technically, you are solving differential equations (and hence using integration) in all three cases.
  • · Replies 26 ·
