Non Homogenous Differential Equation
The discussion revolves around solving a non-homogeneous differential equation of the form y"' - 9y" + 18y' = 30e^x, with initial conditions provided for y, y', and y". Participants are exploring the methods for finding the general solution and particular solution, as well as the constants involved.
  • Mixed
  • The original poster attempts to solve the differential equation by factoring and finding the general solution, while also trying to determine the particular solution. Some participants question the calculations for the constants c_0, c_1, and c_2, suggesting alternative methods such as matrix techniques for solving these constants.
Some guidance has been offered regarding the use of matrix methods to solve for the constants, and there is an ongoing examination of the correctness of the original poster's calculations. Multiple interpretations of the particular solution are being explored, particularly concerning the form of the solution involving A.
Participants are discussing the implications of the roots of the characteristic equation and how they affect the particular solution. There is also a focus on ensuring the correct application of initial conditions in the context of the differential equation.
shards5
y"' - 9y" +18y' = 30ex
y(0) = 16
y'(0) = 14
y"(0) = 11
n/a
Factor Out
r(r2 - 9r +18)
r = 0; r = 6; r =3
General Equation
y(x) = c0 + c1e3x + c2e6x
y'(x) = 3c1e3x + 6c2e6x
y"(x) = 9c1e3x + 36c2e6x
c1 = (11 - 36c2)/9
y'(x) = 14 = 3c1e3x + 6c2e6x
y'(x) = 14 = ((11 - 36c2)/9)e3x + 6c2e6x
c2 = -31/30
c1 = (11 - 36*(-31/30))/9 = 5.35555556
y(0) = 16 = c0 + c1e3x + c2e6x
16 +31/30 - 5.35555556 = c0 = 11.6777778
Solve For A in Aex
yp = Aex
y'p = Aex
y"p = Aex
y"'p = Aex
Inputting into the original equation we get.
Aex - 9Aex +18Aex = 30ex
Simplifying we get.
10Aex = 30ex
Which gives A = 3 and since 3 is a root of the original equation we add an x to differentiate between the two.
So the final equation SHOULD BE 3xex + 11.6777778 + 5.35555556e3x -31/30e6x but of course its not.
So my question is, what am I doing wrong?
Most of your work is fine, but I believe you have made an error in your calculations for c_0, c_1, and c_2. I used matrix methods to solve for these constants and got c_2 = 25/18. I'm fairly confident of this value, but didn't check it.
Also, in your last paragraph you say something that isn't true. You got A = 3, which means that your particular solution is y_p = 3e^x. The fact that you got a value of 3 when you solved for A is irrelevant to anything else in this problem. Your general solution will include 3e^x, not 3xe^x.
When you say matrix method do you just make a matrix like this?
1 1 1 16
0 3 6 14
0 9 36 11
And then you row reduce?
1 1 1 16
0 3 6 14
0 9 36 11
Yes, and yes.
  • · Replies 27 ·
  • · Replies 18 ·
