Velocity of electron moving between charged plates
The discussion revolves around the relationship between the velocity of an electron and the electric field when the electron moves between charged plates. Participants explore various approaches to understand the mechanics involved, including kinematic equations, energy conservation, and the effects of electric fields on charged particles.
  • Some participants inquire about the relationship between velocity (V) and electric field (E), referencing the force (F) and electric field relationship (E=F/e).
  • One participant suggests using kinematic equations to relate acceleration and velocity, indicating that the force causes acceleration, which changes velocity.
  • Another participant proposes that the initial potential energy (eV) converts to kinetic energy, leading to an equation for velocity (v) based on energy conservation.
  • Some participants emphasize that the velocity can be derived from the equation v^2 = 2ax, where acceleration (a) is defined as a = qE/m, linking it to the electric field.
  • One participant notes that using energy considerations simplifies the problem, avoiding the need to discuss distance or time.
  • A participant asks how to find acceleration if both x and y components of velocity and the electric field are given, reiterating the relationship F=ma.
  • Some participants express differing opinions on the complexity of the explanations, with some preferring straightforward approaches while others appreciate more elaborate discussions.
There is no consensus on a single approach to the problem, as participants present multiple methods and perspectives on how to relate velocity and electric field. Some prefer energy methods while others focus on kinematic equations, leading to a variety of interpretations.
Participants assume a constant electric field for their calculations, which is valid for infinite parallel plates. However, the discussion does not resolve the implications of different methods or the conditions under which they apply.
This discussion may be useful for students or individuals interested in classical mechanics, electromagnetism, or those seeking to understand the dynamics of charged particles in electric fields.
jawad khan
whts the relation of velocity V and electric field E?
i only know about E=F/e(relation of electric field E and Force F)
any one like to answer?
Use the kinematic equations of motion. The force causes an acceleration, which is a change in velocity. Are you familiar with those equations?
It's accelerating all the time so I guess you want the speed on impact.
The initial Potential Energy will be eV, where e is the electron charge and V is the Potential difference between the plates.
All this PE will end up as Kinetic Energy (= half m (v squared)), where v is the velocity and m is electron mass.
Look up the constants.
Then equate the two energy values to get an equation which you can solve for v.
This is actually just a mechanics problem if you use the fact that [tex]\vec{F} = q \vec{E}[/tex].
You know that the velocity is,
[tex]v^2 = v_0^2 +2a(x-x_0)[/tex]
You can simplify this somewhat by assuming that the electron starts from rest at one plate, and you can place the origin there.
[tex]v^2 = 2ax[/tex]
You further know that,
[tex]ma = qE[/tex]
So,
[tex]a = \dfrac{q}{m}E[/tex]
Now just substitute this into the kinematic equation of motion,
[tex]v^2 = \dfrac{2q}{m}Ex[/tex]
And now you can easily solve for the velocity,
[tex]v = \sqrt{\dfrac{2q}{m}Ex}[/tex]
As you can see, the speed of an charged particle in an electric field does not depend only on the strength of the field, but also on the distance that it has travelled.
[tex]ma = qE[/tex]
So,
Just to note, this is exactly equivalent to sophie's description. The voltage is Ex and so the potential energy is qEx. This requires that the electric field to be constant, which is true for infinite parallel plates.
Also, by doing it the 'Energy' way, you need not discuss the distance between the plates or consider how long it takes.
It's a one-liner.
dear.if the x-component and y-component of velocity is given i.e Vx &Vy.and E (electric field) is also given. then how to find the acceleration of the electron.
i only know about E=F/e(relation of electric field and force)
F=ma. can you help me in finding acceleration if Vx ,Vy and E is given??
anyone like to answer?
You're quite right, Sophie's treatment of the problem is absolutely correct. I was assuming, however, that he wanted the speed of the particle at every point in space. This is more easily done by setting the kinetic energy equal to the work done by the electric field, but I thought the kinematic description might make more intuitive sense.
The acceleratio is always [tex]\dfrac{q}{m}E[/tex], assuming the electric field is constant.
So why make it straightforward when you can elaborate ad infinitum.
Now, now. There are different ways to approach this problem, depending on what you are looking for. I think that's all they are saying.
Uh, I think I'll stay out of the discussion on which solution is intrinsically superior.
I sometimes like to take the pretty route, too.
