Having trouble finding the angle of deflection of light
The discussion revolves around finding the angle of deflection of light as it passes through a prism. The original poster presents a specific equation to prove, which involves the angles of incidence and refraction in relation to Snell's Law.
  • Participants discuss the application of Snell's Law at the interfaces of the prism and question the assumption that the incident and exit angles are the same. There is also exploration of the relationship between the angles involved and the conditions for minimal deflection.
The conversation has progressed with various participants offering insights into the geometry of the situation and the implications of symmetry in the angles. Some participants have clarified the labeling of angles in the diagram, while others have noted the conditions under which the provided formula holds true. The original poster indicates they have resolved their confusion regarding the angles.
There is mention of a potential mistake in the teacher's diagram regarding angle labeling, which has influenced the understanding of the problem. The discussion also highlights the need for clarity in the assumptions made about the angles involved.
kliker
we have this picture
http://img190.imageshack.us/img190/1128/60283381.jpg
how can i find the angle of deflection?
i must show that it is: sin(A+δ)/2 = n*sinA/2
You need to apply Snell's Law at the the two interfaces. Note that since the incident angle with respect to the normal is the same as the exit angle with respect to the normal, symmetry demands that the ray travel parallel to the base inside the prism. Assume that the prism angle (at top) is known because the angle of deflection depends on it.
thanks but how can we know if the incident angle with respect to the normal is the same as the exit angle?
it doesn't say anything like that, how can we assume this
also
i applied snell but i have sina/sinb = n and sinc/sind = 1/n
also i have proven that A = b + c
http://img130.imageshack.us/img130/6987/50944329.png
im having trouble finding that sin(A+δ)/2 = n*sinA/2 :(
thank you again
As best as I can say from your posted diagram at
both incident and exit angles are labeled θa. Is this not true?
no I think the second one is θb where b = β(the greek letter)
if we supposed that it is the same how could we reach the desired solution?
Referring to your drawing, it is easy to find that the deflection is a+d-A.
The formula you have to prove is valid only for the minimal deflection. The deflection is minimal when the incident and the exit rays are symmetrical: a=d.
ehild
ok guys i figured everything out
the teacher made a mistake it was θα the second one too, it was easy to solve i thought they were different
thanks everyone
  • · Replies 26 ·
