| Thread Closed |
Trig identities help! How to simplify by multiplication/division |
Share Thread | Thread Tools |
| Dec7-09, 02:58 PM | #1 |
Ok guys, here's my problem. I left on vacation with my parents before I learned how to do these correctly. I have been trying and I sorta have the gist of them down. For instance, tan A*sec A simplified is sin A. A=theta. But as I move on they stop making sense, and this is where my problem occurs .I don't know the correct way to do these, but I tried.
1) (tan^2 A)( 1 ) + 1 where A again equals theta -------- ------ sec^2 A sin 2)1+cos A + sin A -------- -------- sin A 1+cos A 3) sin A * cot A * csc A ----- tan A Ok, so on the first one my understanding is to first change them into just sin/cos. What i did was: (sin A^2) 1 1 --------- * --------- + ------ (cos A^2) 1 sin A ----- cos A from here i think i need to do mult. inv. of the middle to get it to just cos A. This is where i get lost. I want to multiply the first 2 now but I get a huge answer then adding the last term just makes it look horrible. On the 2nd one, I cross multiplied and I got (1+cos A)^2 + sin ------------------ = 1 (1+cos A)^2 + sin On the last one I wrote it out again in cos/sin and got sin A cos A 1 ---------- * --------- * ------- sin A sin A sin A ------ cos A Trying to solve this I got cos^2 A --------- sin^2 A If someone could please help me understand these and maybe give me a few pointers I'd very much appreciate it. Thanks! 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Dec7-09, 03:19 PM | #2 |
Mentor
| Dec7-09, 09:00 PM | #3 |
Do you have a right side to any of these equations? Or do you just have to get the equation to the simplest terms?
| Dec7-09, 11:52 PM | #4 |
Mentor
None of them is an equation, at least as posted here. I think the goal here is to simplify the given expressions.
| Dec8-09, 11:46 AM | #5 |
Sorry, I guess that the post messed up what the problem looked like. I'm supposed to simplify them, but I really don't get what to do with tan^2 and how to change everything so that I can simplify. This one is what I mean:
(tan^2 A)(1/sec^2 A) + 1/sin A I think tan^A is sin^2 A/cos^2 A But once I hit sec^2 A I get confused. wouldn't the middle end up being just cos^2 A? Then from there I don't know how to simplify it because the farthest I get (don't know for sure if its even right) is this: sin^2 A/cos^2 A*cos^2 A + 1/sin A |
| Dec8-09, 12:40 PM | #6 |
Mentor
I can't tell what the problem is. In post 1, you have this in post 5.
[tex]\frac{tan^2A}{sec^2A} + \frac{1}{sinA}[/tex] In post 5 you have this: [tex]=~\frac{tan^2A}{\frac{1}{sec^2A}} + \frac{1}{sinA}[/tex] |
| Dec8-09, 12:51 PM | #7 |
I'm sorry for the confusion, its the first one of those 2. I just don't understand how to simplify it because I don't know the subject very well
| Dec8-09, 01:22 PM | #8 |
Mentor
[tex]=\frac{\frac{sin^2A}{cos^2A}}{\frac{1}{cos^2A}} + \frac{1}{sinA}[/tex] Can you continue from here? |
| Dec8-09, 01:37 PM | #9 |
I think so. So it would be:
(sin^2 A)(cos^2 A)/cos^2 A + 1/sin A then cancel out the cos terms correct? so sin^2 A/sin A would be the next step, which I think simplifies to just sin A. Is this right? |
| Dec8-09, 02:31 PM | #10 |
Mentor
| Dec9-09, 12:21 AM | #11 |
Ah, yes your right, I wasn't paying attention to that. Sorry, I don't mean to waste your time, I'll try to get this over with. i think I might have it this time.
sin^2(A) + 1/sinA is adding so I have to get a common denominator. So, I take the denom. of each term and multiply each by the other term so that they will have the same base. so i did sin^2(A)/1 + 1/sinA which after getting a common denominator became sin^3(A)/sinA then it simplifies to sin^2(A) Is this correct? |
| Dec9-09, 12:40 AM | #12 |
Mentor
Up to sin^2(A)/1 + 1/sinA you were right on the money, but then went rapidly downhill. The step you skipped (or at least didn't show) was [tex]\frac{sin^3 A}{sin A} + \frac{1}{sin A}[/tex] Now, both denominators are the same, so what do you get when you add the two expressions? |
| Dec9-09, 10:07 AM | #13 |
Oh, I see, so its sin^3(A) + 1/sinA?
Then it ends up as sin^2(A) + 1 Is that correct now? |
| Dec9-09, 11:21 AM | #14 |
Mentor
Your problems indicate a lack of understanding of how fractions are added. What we're doing here is no different from the ordinary fraction arithmetic. Your first mistake in this post is like saying that 8/2 + 1/2 = 8 + 1/2 instead of (8 + 1)/2. 8 + 1/2 is 8.5, while (8 + 1)/2 = 9/2 = 4.5. Your second mistake (assuming that you meant (sin^3(A) + 1)/sinA) is like saying that (8 + 1)/2 = 4 + 1. I think you might be "cancelling" when you have no justification for doing this. Cancelling is removing identical factors from the numerator and denominator. Factors are expressions that are multiplied together. In this case, neither sinA nor 2 is a factor. If I were you, I would definitely brush up on fractions and rational expressions. The work you are doing in precalculus requires that you have solid working skills in these areas. |
| Dec9-09, 02:12 PM | #15 |
Ya, I see my mistake and understand how to correct it now. I had forgotten that you cant just cancel them out because like you said, I can't justify it. I have been working on these problems for the past 3 days now and I'm finally getting the hang of it. Thank you soooooo much for your help. I've been using what you posted as a guideline and It has helped a lot.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Trig identities help! How to simplify by multiplication/division
| Arbitray integer division/multiplication Python Mathematica | Math & Science Software | 0 | ||
| Trigonometric Identities- simplify sin^4x - cos^4x | Precalculus Mathematics Homework | 4 | ||
| Multiplication and division in physics | General Physics | 8 | ||
