Power calculations can you check?
This discussion focuses on power calculations for a turbine using a single pair of magnets at 1 RPM with a 34-inch diameter rotor. The calculations involve determining the voltage generated per phase, which is calculated to be 0.722 volts, and the current, which is 4.578 amps, based on the resistance of 0.1578 ohms for seven coils. The user also highlights the need for more advanced modeling tools like COMSOL for accurate estimations of magnetic field strength across multiple turns, as hand calculations become impractical for complex systems.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Basic knowledge of electrical resistance and Ohm's Law
  • Familiarity with coil design and winding techniques
  • Experience with magnetic field calculations and properties of magnets
  • Research the use of COMSOL for 3D electromagnetic modeling
  • Learn about multi-phase power generation and conversion techniques
  • Explore advanced calculations for magnetic field strength in coil systems
  • Investigate methods for optimizing coil resistance and efficiency
Engineers, hobbyists, and researchers involved in electromagnetic design, power generation systems, and those seeking to optimize turbine performance using magnetic fields.
xclr82xtc
this is a power calcualtion using 1 magnet pair with the turbine turning at 1 rpm..34 inch diameter rotor. i hope someone else can make sure I am at least doing it right, and i need help converting my single phase numbers to 3phase wye
________________________________________
coil info
1x1x2
80 turns total, 4 rows of twenty.
center line of coil is 34 inches.
the magnets making 1 revolution per minute would pass the coils at X coils per second...lets figure out X
circumference of a 34 inch circle = 106.8 inches
divide that by 60 seconds...106.8/60= 1.78
so EVERY SECOND...the magnets travel 1.78 inches. in turn, the magnetic fields pass through the coils at the rate of 1.78 inches per second?
am i right to this point?
there is 80 coils in 2 inches, so in 1.78inches we would have 71.2
the tesla of the magnets is .6403
the area is .75inchx2inch then change to meters squared = 0.003610meters squared
faradays law
N = -1 * (-V/ (( tesla * area meters squared)/ seconds))
71.2=-1*(-V/((.6403*.003610)/1.78)
-71.2=(-V/.00129)
.0918=V
so right now we have 71.2 turns = ..0918 v at at rate of 1 rpm...
now there is 7 coils of 80 so that's 560 total turns
divide by 71.2 =7.87
so times 7.87 time the Voltage .0918
=.722 volts per phase...
my math looks more right this time lol
now how many feet of wire in a coil (we need to find the resistance)
wire info
Nominal Diameter: 0.10 inch
Nominal OHMS/LB. -20 Celsius: 0.0314
Feet/LB: 31.48
outersize of coil is 1 inch. 4 layers and the core is .6inches.(yes this does take into account wire size) .so the perimter for one layer of turns is (.7*4)+(.8*4)+(.9*4)+.(1*4)=2.8+3.2+3.6+4=13.6inches
now the coil is 2 inches long so we need have 20 layers...20*13.6=272inches...divde by 12=22.6 feet or wire per coil...nice. lol
ok so now we know we have 7 coils so 22.6*7 = 158.2 feet.
its 31.48 feet per lb so 158.2/31.48=5.025lbs
5.025 * .0314=.1578
so the TOTAL resistance of all seven coils is .1578ohms
_____________________________________________________
so now we know the total voltage of one phase at 1 rpm of the mill, and we know the constant resistance of the coil. (i also have the inductance of each coil but i don't think we need it.)
so with this info, we SHOULD be able to figure out the amps using ohms law. i=v/r
.722/.1578=4.578AMPS
SOOOO...per phase, at 1 rpm we have 1.29 volts and 4.578amps. kinda crappy, but hey its only turning at 1 rpm, and that's only using 1 pair of magnets, there is 15 total pairs.
You can't do it that simply. Magnetic fields drop rapidly with distance from the source. Therefore, you need to estimate the field strength separately for each turn.
Software packages such as COMSOL can do the 3D modeling needed for that, but hand calculations are not practical.
9K
  • · Replies 77 ·
10K
11K
15K
