Calculating Gravitational Potential Energy for a Spoon on a Table
The discussion revolves around calculating the gravitational potential energy of a spoon raised above a table, with specific values for mass and height provided. The subject area is gravitational potential energy within the context of physics.
  • Participants discuss the necessary conversions of mass from grams to kilograms and height from centimeters to meters to ensure consistent units for calculating gravitational potential energy. There are questions about the free-fall acceleration and its value, as well as the correct application of the gravitational potential energy formula.
The discussion is active with participants exploring unit conversions and the implications of using inconsistent units. Some guidance has been provided regarding the importance of unit consistency, and there are attempts to clarify the correct setup of the equation for potential energy.
Participants note the need for unit conversions and the potential confusion arising from inconsistent measurements. There is an emphasis on ensuring that the final answer is expressed in joules.
Kiko:)
A spoon is raised 21.0 cm above a table. If the spoon and it's contents have a mass of30.0g, what is the gravitational potential energy associated with the spoon at that height relative to the surface of the table?
I know that the equation for gravitational potential energy is PEg=mgh
I know that the mass is 30.0g and the height is 21.0 cm. But how would you figure out the free-fall acceleration?
By knowing that for most bodies in the proximity of the earth, g (the grav constant)=9.8m/s-s. That is the free fall acceleration.
would you convert the 30.0g to kilograms? since the answer is suppose to be in joules
Yes.
For the potential energy answer, yes you must. Inconsistent units of measurements lead to wrong results.
The importance of specifying units is undercut at times here because of the time involved.
so then the equation would look like this?
.03kg x 9.8 m/s-s x 21.0cm = _________ J
Close. The prevailing system uses Kg-meters-seconds. Joules is based on these. Convert cm to m.
Ah so .03kg x 9.8 m/s-s x .021m = 6 x 10^3 J
is that right?
is that right?
pull the handle and see the wheels spin. (my own wish, I assume the right/wrong confirmation is less dramatic).
Yea you're ok
Yea you're ok
Thankyou so much!
i ment to put 6 x 10^-3 J
14K
