Energy levels of Lithium. Quantum.
The discussion revolves around calculating the energy levels of Lithium, specifically focusing on the first few energy states while ignoring electron-electron repulsions. The original poster references the hydrogen atom's energy formula and attempts to adapt it for Lithium by adjusting the charge.
  • Exploratory, Assumption checking
  • Participants discuss the application of a formula for energy levels and question the appropriate combinations of quantum numbers (n, n', n'') to use for calculating the first five energy levels. There is a debate about the correct sets of quantum numbers that yield the lowest energy states.
Some participants have provided guidance on evaluating the energy formula with different quantum number combinations. The original poster acknowledges a mistake in their approach and seems to be moving towards a clearer understanding of the correct combinations. There is an ongoing exploration of how to determine the order of energy levels based on the combinations used.
Participants are operating under the assumption that electron-electron repulsion is negligible, which influences their calculations. There is also a mention of potential confusion regarding the interpretation of the energy formula, which has led to differing opinions on the correct quantum number combinations.
vwishndaetr
I am having an issue calculating the first few energy levels of Lithium. To add, electron-electron repulsions are ignored.
Since electron-electron repulsion is being ignored, I am starting with the following,
For Hydrogen,
[tex]E_n=-\left[\frac{m}{2\hbar^2}\left(\frac{e^2}{4\pi\epsilon_0}\right)^2\right]\frac{1}{n^2}=\frac{E_1}{n^2}[/tex]
Where the ground state, n=1,
[tex]E_1=-\left[\frac{m}{2\hbar^2}\left(\frac{e^2}{4\pi\epsilon_0}\right)^2\right]=-13.6eV[/tex]
As mentioned, since we are ignoring electron-electron repulsion, the only difference will the amount of charge.
So substituting,
[tex]e^2\rightarrow3e^2[/tex]
So for Lithium,
[tex]E_n=-\left[\frac{m}{2\hbar^2}\left(\frac{3e^2}{4\pi\epsilon_0}\right)^2\right]\frac{1}{n^2}=-9\left[\frac{m}{2\hbar^2}\left(\frac{e^2}{4\pi\epsilon_0}\right)^2\right]\frac{1}{n^2}[/tex]
But we know,
So,
[tex]E_n=-9\left[\frac{m}{2\hbar^2}\left(\frac{e^2}{4\pi\epsilon_0}\right)^2\right]\frac{1}{n^2}=9\frac{E_1}{n^2}[/tex]
With this we can conclude that,
[tex]E_t=\left(E_n+E_{n'}+E_{n''}\right)[/tex]
So,
[tex]E_t=9\left(\frac{E_1}{n^2}+\frac{E_1}{n'\ ^2}+\frac{E_1}{n''\ ^2}\right)[/tex]
Now here is where my question comes in. I need to find first five energy levels of Lithium. I am a little confused on to which values of n, n', and n'' to choose.
A friend of mine said that first five states would be, 1 1 2, 1 1 3, 1 1 4, 1 1 5, and 1 1 6.
I on the other hand think it should be, 1 1 2, 1 2 2, 1 1 3, 2 2 2, and 1 2 3.
Can someone shed some light? I always thought to go by the sums of the squares of each n combination. So my order follows chronologically from lowest to the next possible energy level. His on the other hand, seem to skip one's that I think should be present.
All help is appreciated!
[tex] E_t = 9\left(\frac{E_1}{n^2}+\frac{E_1}{{n^{\prime}}^2}+\frac{E_1}{{n^{\prime \prime}}^2}\right)[/tex]
You have a nice formula for the energy. Why don't you evaluate it for different n, n' and n'' values and compare them with one another?
That is what I'm doing.
The states that are listed above, "1 1 2, 1 2 2, 1 1 3, 2 2 2, and 1 2 3", I plugged into that equation. The first number being n, second, n' and third being n''.
For example, 1 1 2, the ground state would be,
[tex]E_t = 9\left(\frac{E_1}{1^2}+\frac{E_1}{{1}^2}+\frac{E_1}{2^2}\right)= 9\left(\frac{E_1}{1}+\frac{E_1}{1}+\frac{E_1}{4}\right)= \frac{81E_1}{4}= \frac{81(-13.6\ eV)}{4}= -275.4\ eV[/tex]
I understand how to use the formula.
Well let me ask this, do I need to use combinations of n, n', and n'' such that the energy levels increased minimally from one another?
What I think should be true is that E2 cannot be say 300eV if a combination of n's allows an energy of 295eV. So 295eV should be E2, not 300eV.
Get where I'm coming from? I just need to know if the last statements are true.
Bummer. I made a careless error. What a waste of time typing.
I, like a knuckle head did not actually try the states I suggested. I was looking at it as,
[tex]E = \left({n^2}+{{n^{\prime}}^2}+ {n^{\prime \prime}}^2}\right)[/tex]
rather than,
[tex]E = \left(\frac{1}{n^2}+\frac{1}{{n^{\prime}}^2}+ \frac{1}{{n^{\prime \prime}}^2}\right)[/tex]
I was careless. So 1 1 2, 1 1 3, 1 1 4, 1 1 5, and 1 1 6 are the correct ones.
Thanks for the help though.
rather than,
I'm sort of confused. If you thought it was [tex]E = \left({n^2}+{{n^{\prime}}^2}+ {n^{\prime \prime}}^2}\right)[/tex], then wouldn't the lowest states be n=infinity, as then you'd get a huge negative number.
I hear you on that part.
I was thinking the same thing, and am going to ask the good ol' professor tomorrow.
