Counting Lattice Points in a Circle: A Math Contest Question
The discussion revolves around a math contest question regarding the determination of the total number of lattice points within a circle of radius 6 centered at the origin. Participants explore various methods for solving this problem, including graphical approaches and potential formulas.
  • Homework-related
  • One participant suggests counting the lattice points in one quadrant of the circle and then multiplying by four, while being cautious about double counting points on the axes.
  • Another participant proposes working through cases by counting points in the first quadrant and using symmetry to find the total number of points.
  • A later reply mentions a formula related to Gauss's circle problem, which provides a way to calculate the number of lattice points within a circle of radius R.
  • Some participants express a desire for a general formula applicable to circles with different centers and radii, indicating a need for clarity in self-study.
  • One participant encourages others to experiment with smaller circles to derive their own general formula, suggesting that hands-on exploration may aid understanding.
Participants do not reach a consensus on a single method or formula for counting lattice points, and multiple approaches and perspectives are presented throughout the discussion.
Some participants express uncertainty about complex solutions and the applicability of formulas, indicating a potential gap in understanding or familiarity with the topic.
Individuals interested in mathematical problem-solving, particularly in combinatorial geometry and number theory, may find this discussion relevant.
yik-boh
In a math contest, the question goes somehow like this:
A lattice point is a point wherein the value of (x,y) is an integer. Determine the total number of lattice points in a circle which has a radius of 6 and the its center is at the origin.
Any one knows the solution or shortcut for this?
you could draw a quadrant of a circle of radius 6 and check the number of points there and multiply that number by four, being careful not to double count points that lie on the axis,
as for a closed form, i would be surprised if one did not exist...
Side note
Wolfram indeed does have a interesting write up in regards to this problem.
Wolfram? Sorry I'm still new to the community.
I guess crd refers to: http://mathworld.wolfram.com/ which is a math resource, but I don't know the particular write-up he mentioned.
Anyway just work it out in cases. As crd suggested just count the points in the first quadrant (which we can take to include the positive x-axis, but not the positive y-axis because then we get simple rotational symmetry without double-counting), and then use symmetry to deduce the total number. In that case the x-coordinate is 1,2,3,4,5 or 6.
When the x-coordinate is x, then the y-coordinate must be less than or equal to [itex]\sqrt{6^2-x^2}[/itex], so for any x-coordinate you want to count the integers in [tex][0,\sqrt{6^2-x^2}][/tex]Try to see how far you can get, and if you get stuck at a particular step just ask for more help.
I'm still not familiar in self studying especially with those complex solutions.
Can someone write a general formula for me which I could use when I'm given the center of the circle and the length of the radius. That would be a very big help. Thanks.
See the link by crd. It states:
Gauss's circle problem asks for the number of lattice points within a circle of radius R
[tex]N(R) = 1+4\lfloor R\rfloor + 4\sum_{i=1}^{\lfloor R\rfloor}\left\lfloor\sqrt{R^2-i^2}\right\rfloor[/tex]
Which is exactly what you would get if you split it into cases.
Why not try looking at a circle of radius one centered at the origin, counting the points of interest there? Then look at a circle of radius 2 centered the origin, and count those points. Then a circle with radius 3, a circle with radius 4, radius 5, ..., radius n, and maybe you will be able to come up with your own general formula for what you are looking to solve, and more than likely you will be able to expand what you found from your trials to a circle with an integer radius centered at a lattice point.
I think that's the easiest way to make sense of formulas, once your hands already dirty in what you are working with, what other people have discovered falls into place just that much easier, other wise you are pushing around symbols that have no meaning to you.
  • · Replies 16 ·
