How to Calculate Heat Loss and Gain in a Melting Ice Scenario?
  • Thread starter Thread starter cashellz77
    Heat
The discussion revolves around calculating heat loss and gain in a scenario involving melting ice and water. The problem includes specific masses, specific heat capacities, and initial temperatures for both the ice and the water.
  • Mixed
  • Participants explore the relationship between heat lost by the water and heat gained by the ice, questioning how to set up the equations correctly. Some suggest using the concept of thermal equilibrium, while others emphasize the need to account for the heat of fusion in the calculations.
Participants have provided guidance on setting up the equations for heat transfer and have clarified the need to include the heat of fusion in the calculations. There is an ongoing exploration of how to apply the equations based on the provided information.
There is a mention of missing information in the initial posts, with participants seeking clarification on the full problem statement. The discussion also highlights the importance of understanding the heat of fusion in the context of melting ice.
cashellz77
heat Lost Heat Gained
M=.213 kg M=.868
C=2090 J/kg K C=4186 J/kg K
To=0 To=26.5
T=? T=?
Q=mc(delta T
I can not figure this out , I have tried and tried with no luck.
M=.213 kg M=.868
To=0 To=26.5
T=? T=?
Q=mc(delta T
Heat flows from the hotter to the colder until they reach the same temperature. So you know that the temperature of each mass will be the same when equilibrium is reached. You have to determine the final temperature.
Your equation for the heat flow is correct. So the equations for the change in temperature in terms of initial and final temperature are:
[tex]Q_1 = m_1C_1(T_1 - T_f)[/tex]
[tex]Q_2 = m_2C_2(T_f - T_2)[/tex]
What is the relationship between Q1 and Q2? That will enable you to solve for Tf.
AM
Welcome to PF, Cashelz.
I don't think you have typed in the whole question - not exactly sure what the question is!
Generally in these heat questions you write
heat lost by one material = heat gained by the other
mC*ΔT = mC*ΔT
I think your ΔT for the water will be (26.5 - T) where T is the final temperature.
For the other material, looks like ΔT = (T - 0).
Try putting all the info into the equation and see if you can find T.
Hello Thankyou! The queastion reads An ice cube with a mass of .213kg and a temp. of0.00c is placed in a Styrofoam cup containing .868 of water at a temp. of 26.5 c . What is the final temp. of the water after the ice cube has melted?
Glad you gave us the question! Our previous answers do not apply to this question, which involves the melting of ice. It takes heat to melt ice, called the heat of fusion. So
heat lost by water = heat of fusion of ice + heat gained by ice after melting
You should look up "heat of fusion" in your book and get the formula for it.
  • · Replies 17 ·
