How can I build a radio tuned to 120.55 Mhz using a simple circuit?
  • Thread starter Thread starter Phymath
    Radio
The discussion revolves around building a radio tuned to 120.55 MHz, exploring the necessary components and circuit design for both AM and FM reception. Participants share their experiences and knowledge regarding passive radio circuits, specifically focusing on the use of inductors and capacitors to achieve resonance at the desired frequency.
  • Homework-related
  • One participant proposes using a 1 microhenry inductor and a 1.743 picofarad capacitor to achieve resonance at 120.55 MHz, questioning whether this setup would work and asking for a schematic.
  • Another participant shares their experience of building a simple AM radio with a passive setup, involving a tank circuit connected to a diode and earphone.
  • A different participant discusses the circuit's limitations, stating it is a simple form of AM radio that typically does not receive FM stations and suggests using a variable capacitor for better tuning.
  • One contributor mentions that these passive radios, referred to as "crystal radios," do not require power sources and can be built creatively with basic components.
  • Another participant notes the abundance of information available online about crystal radios.
Participants express varying opinions on the effectiveness and sensitivity of the proposed circuit designs, with some agreeing on the basic principles of passive radio construction while others highlight limitations and suggest alternative approaches. No consensus is reached regarding the feasibility of the specific design for 120.55 MHz reception.
Participants mention different component values and configurations, indicating that assumptions about component quality and circuit design may affect performance. The discussion does not resolve the effectiveness of the proposed designs or the suitability for receiving FM signals.
Individuals interested in radio construction, electronics hobbyists, and those exploring passive radio technologies may find this discussion relevant.
Phymath
How would u make a radio that's tuned into 120.55 Mhz? or any frequency? I thought you would fallow this formula...
(120.55 * 10^6 Hz) = 1/(2 pi sqrt(LC)), where L is the inductence, and C the capacitor. well i figured a 1 micro (10^-6) Henry inductor and a 1.743 pF (10^-12) would create the resonance frequency of 120.55 Mhz and thus that radio station would come in on the sieres circut i created, but would this acutally work? what would be the actually schematic where to place the anntenna, ground, diode, head phones, etc.. thanks to anyone who can explain to me if or how it will work
-Phymath
I've seen that
One of my instructors showed us a simple AM radio he built with just that type of setup. It was a totally passive radio. A simple antenna lead to a tank circuit... the tank circuit was in parallel to another parallel branch that had a diode and capacitive earphone (single earphone).
Why 120.55 Mhz is there at strong station there , and if so is it AM or FM .
The type of circuit your referring to is the simplest form of AM radio. It comprises a parallel tuned circuit using a cap of say 20 pf ( usually a variable ) with suitable inductor per your calc. of good Q . They used to wind them . The antenna ( wire of several feet )is connected to one end of the // pair and a ground "large metal chassis'
to the other. A diode is connected from the antenna side to some earphones and then back to ground. The earphones should be coil types NOT capacitive.
This circuit is NOT very sensitive and used to be used for longwave radio reception at 500Khz or so. It will not receive FM stations .
If your really serious you may wish to look at some modern chips which can be the basis of very sensitive circuits , but they require a fair amount of support components.
Ray.
Hi.
What RFbeginner told U is a good project, I made once this type. U don't have to use power sources or batt's, only a big antenna, an earphone (like the old phones), and creativity making the inductance. It works better if you use a mobile indictance inside the first one.
Bye.
These sorts of passive radios are called "crystal radios," by the way, and the web is teeming with info about them.
- Warren
11K
  • · Replies 33 ·
