Solving a Limit Without L'Hopital's Rule
  • Thread starter Thread starter holezch
    Limit
The problem involves evaluating the limit of the expression (2+y^2)/sqrt(4+y^4) as y approaches positive infinity, with the constraint of not using L'Hôpital's rule.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss dividing the expression by y^2 to simplify the limit evaluation. Some express confusion about the behavior of the denominator as y approaches infinity, while others suggest analyzing the components separately.
There are multiple lines of reasoning being explored, including the implications of the limit approaching an indeterminate form. Some participants offer insights into the relationship between the numerator and denominator as y becomes large, while others provide suggestions for factoring and further simplification.
Participants note the restriction against using L'Hôpital's rule, which influences their approaches to the problem. There is also a mention of the behavior of the components of the limit as y approaches infinity.
holezch
(2+y^2)/sqrt(4+y^4) as y goes to positive infinity
I divided it out by y^2 to get
lim y-> inf+ (2+y^2)/y^2 = 1 and the bottom lim y -> inf+ sqrt(4+y^4)/y^2 I can't solve..
by the way, I can't use l'hospital's rule
thanks!
Split them into 2.
1. [tex]2 + y^2[/tex] --> inf as y --> inf
2. [tex]1/sqrt(4 + y^4)[/tex] --> 0 as y -- inf
So you are having an inf / 0 situation.
Unto said:
Split them into 2.
I know, that's why divided it out by y^2.. so the question really comes down to solving
thanks for reading
First of all, notice that (2+y^2)^2=(4+4y^2+y^4)>(4+y^4) for y positive.
This means (2+y^2)>sqrt(4+y^4)... which means that the limit you're looking for is either greater than or equal to 1 or infinite (why?).
As for evaluating the actual limit, you might find it easier to first deal with the ratio (4+4y^2+y^4)/(4+y^4)
thanks!
Factor y^2 out of both the numerator and denominator and then take the limit.
[tex]\frac{2 + y^2}{\sqrt{4 + y^4}}~=~\frac{y^2(2/y^2 + 1)}{y^2\sqrt{4/y^4 + 1}}[/tex]
Can you finish it?
Can you finish it?
thanks, I can see that for large y, it is 1
Yes. And you can see that in the original expression, as well. For large y, the numerator is pretty close to y^2, and the denominator is also pretty close to y^2, since the square root of y^4 is y^2. The constants in the top and bottom are less and less significant the larger y gets.
  • · Replies 21 ·
