Break white light into it's components
The original poster seeks to demonstrate that white light is composed of different colors but lacks a prism for the demonstration. They have a white LED flashlight and have attempted various objects to decompose the light without success, leading them to question whether the light from a white LED differs from ordinary white light.
  • Exploratory, Assumption checking
  • Participants discuss the differences in light spectrum between white LEDs and incandescent bulbs, suggesting that the LED spectrum can be found in its datasheet. They propose using alternative materials like plastic or glass to achieve the desired effect, as well as using colored transparent materials to demonstrate color composition. Additionally, the use of a CD as a tool for splitting light is suggested.
Participants are exploring various methods to demonstrate the decomposition of white light without a prism. Some have provided suggestions for alternative materials and tools, while others have shared insights about the nature of white LEDs and their light spectrum.
The original poster is constrained by the lack of a prism and is exploring improvisational methods to achieve their demonstration. There is an ongoing discussion about the differences in light produced by various sources.
Alkhimey
Hi,
I need to make a demonstration that shows that white light is composed of different colors. I do not have a prism, and will not be able to obtain one in time. I have a white LED flash light, and I tried some improvisations with different objects (bottles, glasses etc), but none seems to decompose the white light. This led me into thinking, is light produced by white LED somehow different from the ordinary white light?
Maybe you can think of some other improvisation that demonstrates the effect I need?
Thank you for the help.
Alkhimey said:
Hi,
Yes, the light spectrum of a white LED is different from the spectrum of an incandescent bulb. You should be able to find the LED spectrum in its datasheet, and the spectrum of an incandescent bulb from a google (images) search.
Even though you don't have a "prisim", do you have access to any blocks of plastic or glass? Even a square drinking glass can be made to split out the spectral components for you. Or use a slit on top of a pan of water, and shine the light in at an angle...
Or as you suggest, shine the white light through various transparent colored materials, and show that the original light had some of that color in it...
Most (all?) white LED's are composed of a red, a blue, and a green LED that, when combined, give white light. Remember that LED's work when electrons recombine with holes and give off photons with the same energy as the semiconductor's energy gap. That means all "pure" LEDs give off a single wavelength of light.
If you want to split light, why not use a CD? I've used it to look at LEDs, fluorescent lamps, incandescent bulbs, and even the spectral absorption lines of the Sun. It works quite well.
Hah! Very cool idea.
  • · Replies 40 ·
  • · Replies 207 ·
16K
43K
  • · Replies 24 ·
