Matlab - checks on imported data
  • Context: MATLAB
  • Thread starter Thread starter bakes1
    Data Matlab
This discussion focuses on importing accelerometer data from an Excel document into MATLAB using the xlsread function. The user aims to implement a threshold check on the imported data values for three axes (x, y, z) to trigger flags when values exceed a specified threshold. The proposed solution involves using a for loop combined with if statements to evaluate each data point against the threshold, with flag variables initialized to indicate whether any values exceed the threshold. The user seeks guidance on the implementation details within the MATLAB script.
  • Familiarity with MATLAB programming, specifically using xlsread
  • Understanding of basic control structures in MATLAB, including for loops and if statements
  • Knowledge of data types and indexing in MATLAB arrays
  • Experience with threshold-based data analysis techniques
  • Explore MATLAB's xlsread function documentation for advanced usage
  • Learn about MATLAB array indexing and manipulation techniques
  • Investigate creating custom functions in MATLAB for modular code
  • Research best practices for implementing threshold checks in data analysis
This discussion is beneficial for MATLAB users, data analysts, and engineers working with sensor data who need to implement threshold checks and data validation techniques in their projects.
bakes1
A bit of background~
I'm using a wii mote to collect accelerometer data, and have the data exported to an excel document.
This data is then imported into MATLAB using :
a = xlsread(fileName); %reads in file name
x = a(:, xColNum); %time
y1 = a(:, y1ColNum); %accel value x
y2 = a(:, y2ColNum); %accel value y
y3 = a(:, y3ColNum); %accel value z
what i'd like to do next is then set a threshold check so that if any of the values within each of the sets is greater than a decided value a trigger can be set.
I'm not sure how to run the initial check on the y1, y2 ,y3 values. My first thoughts are to run a for loop on the sets and then have if statements that execute when the given values are reached. My only problem is I'm not quite sure how to code this within the m file. Also should it be part of a separate function of just below the above code.
You could have three flag variables, one for each column, that are initialized to 0 and are set if you find a value that is above the threshold in a particular column. If you're interested only if any value in any of the three columns is above the threshold, you can probably get by with just one flag variable.
Code:
flag1 = 0
flag2 = 0
flag3 = 0
Threshold = 10000 % or whatever
for i=1:N
  if y1(i) >= Threshold
    flag1 = 1
  end
end
  • · Replies 18 ·
11K
