What is the difference between O and O2 in stoichiometry calculations?
  • Thread starter Thread starter Whalstib
    Stoichiometry
The discussion centers on stoichiometry calculations involving the reaction 4Al + 3O2 → 2Al2O3. The key point is that when calculating the limiting reagent, one must use O2 (oxygen gas) rather than O (atomic oxygen) since the reaction is balanced with O2. The calculations confirm that with 20g of aluminum and 15g of O2, aluminum is the limiting factor, producing 0.37 moles of Al2O3, while the correct approach using O2 yields 0.625 moles of Al2O3 produced.
  • Understanding of stoichiometry and chemical reactions
  • Knowledge of molar mass calculations
  • Familiarity with limiting reagents in chemical equations
  • Basic principles of balancing chemical equations
  • Study the concept of limiting reagents in greater detail
  • Learn how to balance chemical equations effectively
  • Practice stoichiometry problems involving diatomic molecules
  • Explore the implications of using different forms of elements in calculations
Chemistry students, educators, and anyone involved in chemical calculations or stoichiometry who seeks to clarify the distinction between O and O2 in reaction contexts.
Whalstib
Hi,
4Al + 3O2 --->2Al2O3
Given 20g of Al and 15g Oxygen which is limiting factor?
My question is the difference between O2 and Oxygen. Do I start with a mole of O or O2 in my calcs? Since the question is framed "15g of oxygen" (verbatim from a quiz) should it be inferred it's O2 in which case it's 32g/mol as opposed to 16g/mol, either .47 moles O2 or .94 moles O...?
I used the O 16g/mol calc.
15g O2 x 1(mole O)/16 (mm O) x 2(mol Al2O3)/3(mol O) = 0.625 moles Al2O3 produced
20g Al x 1(mole Al)/27 (mm Al) x 2 (mol Al2O3)/4 (mol Al) = 0.37 moles AlsO3 produced
With this approach Al is limiting factor. Professor briefly touched upon this problem and I had not chance to question. he was clear that O was limiting factor.
is it my O vs. O2 calculations?
Should my O calc be:
15g O2 x 1(mol O)/32 (mm O2) x 2(mol Al2O3)/3(mol O) = 0.312 moles Al2O3 produced.
Thanks!
Warren
While 15 g of oxygen is 0.47 moles of O2 and 0.94 moles of O, it is still the same number of atoms (that is, amount of oxygen has not changed). However, your reaction is balanced with O2 - so you should use moles of O2 for calculation. If you use reaction balanced with O (that is, 2Al + 3O -> Al2O3) you use moles of O. That's not reasonable approach as oxygen is diatomic, but it will still give correct result.
And yes, Al is a limiting reagent.
10K
11K
10K
