| Thread Closed |
Beat frequencies/tension force of violin strings while tuning--please help |
Share Thread |
| Dec11-09, 11:58 PM | #1 |
To tune your violin, you first tune the A string to the correct pitch of 440 Hz, and then you bow both it and the adjoining string simultaneously, all the while listening for beats. While bowing the A and E strings, you hear a beat frequency of 3.00 Hz and note that the beat frequency increases as the tension on the E string is increased. (The E string is to be tuned to 660 Hz) (a) Why are the beats produced? 2. Relevant equations 3. The attempt at a solution I wrote that the beats were caused due to constructive/destructive interference, but the answer is that "The fundamentals of A and E differ too much to cause a beat frequency of 3hz, therefore it must be caused by the harmonics of A and E." It then says " So the E string must be slightly greater then 660hz because the beat frequency increases as the tension force increases." I understand that the beat frequency increases as the tension force increases, maybe not why, but ok, I hear it, but I don't get how he figured out the E string must be slightly greater then 660hz.. How can you tell the beat freq increased at all? I don't really get how he came to that conclusion. What if it was lower then 660hz? What would the beat freq look like? Also, what really is a fundamental or harmonic? I know what it means in terms of calculating stuff, but what is it? Is is different sections of the wave? Is it cycles of the wave? For every wave is there a fundamental wave, a harmonic wave (1,2,3,4 and so on)? I just dont get what they are in essence I guess. |
| Dec12-09, 12:25 AM | #2 |
Recognitions:
| Dec12-09, 12:42 AM | #3 |
The beat frequency can't be negative right? So how do we know its not less then 660? what did the beat frequency increase from to get to 3? If its any positive number its about 660? I just don't get that.. So can a string vibrate with all the harmonics at once? When you pluck a string, does it start vibrating at some harmonic and start changing numbers as it dies down? |
| Dec12-09, 02:38 AM | #4 |
Recognitions:
Yes, the beat frequency can't be negative; it's just the difference between two frequencies.
The question says the beat frequency was 3, THEN it increased after tension was increased. So there are two possibilities. You know the A string is at 660 Hz (well, one of its harmonics is), so the E string can either be at 657 or 663 Hz. If you increase the E string's frequency by, say, 1 Hz, it will be at either 658 or 664 Hz. 658 Hz is closer to 660 Hz; 664 is farther. |
| Dec12-09, 03:09 AM | #5 |
Here's an example of the fundamental and it's harmonics. All these waveforms (and even higher order ones) exist on the plucked string at once. The first one is the fundamental: This picture is from the wiki on the harmonic series (music): http://en.wikipedia.org/wiki/Harmoni...es_%28music%29 There's a mathematics harmonic series wiki too |
| Dec12-09, 09:29 AM | #6 |
The fundamental of the A string is 440Hz
The 2nd harmonic (1st overtone) is 880Hz The 3rd harmonic (2nd overtone) is 1320Hz These are whole multiples of 440 The fundamental of the E string is 660Hz The 2nd harmonic (1st overtone) is 1320Hz These are whole multiples of 660 The beats occur between the harmonics at 1320Hz. The beat frequency of 3Hz means, in this case, that the E string 2nd harmonic is at 1323Hz - slightly sharp. I know this because increasing the tension in that string makes it slightly sharper and the beat frequency increases. Musically, you hear the 2nd harmonic as the note an octave above the fundamental. The 3rd harmonic is a 5th above that. So in this case, the beats are between two E notes. The one is the octave above the E string. (2nd harmonic on that string) The other is the E which is the 3rd harmonic on the A string. |
| Dec12-09, 06:46 PM | #7 |
Ok.. I'm understanding it much more now guys.. Thanks a lot :)
| Thread Closed |
Similar discussions for: Beat frequencies/tension force of violin strings while tuning--please help
| Beat Frequencies & Light | General Physics | 3 | ||
| Need urgent help, beat frequencies and tuning. | Introductory Physics Homework | 7 | ||
| tuning a violin (beats) | Introductory Physics Homework | 3 | ||
| Beat frequency of 3 tuning forks | Advanced Physics Homework | 3 | ||
| Beat frequencies | Electrical Engineering | 13 | ||
