Describe the cycloid described by a wheel rolling inside a circle
  • Context: Graduate
  • Thread starter Thread starter JanClaesen
    Circle Rolling Wheel
The discussion focuses on the mathematical description of a cycloid generated by a wheel rolling inside a larger circle. The position vector of the point on the wheel in contact with the larger circle is defined by the equation r = r cos(w t)e(x') + r sin(w t)e(y'), where w represents the angular velocity. The absolute position vector p is given by p = (R - r) cos((r/R) w t)e(x) - (R - r) sin((r/R) w t)e(y), with R being the radius of the larger circle and r the radius of the wheel. The error in plotting an astroid when R = 4r arises from not accounting for the additional circular motion of the smaller wheel, which requires adjusting the angular displacement to (R/r)wt + wt.
  • Understanding of cycloid geometry and parametric equations
  • Familiarity with angular velocity and its implications in circular motion
  • Knowledge of vector notation and unit vectors in two-dimensional space
  • Basic principles of rolling motion and non-slip conditions
  • Explore the mathematical properties of cycloids and their applications in physics
  • Study the derivation of parametric equations for curves generated by rolling objects
  • Learn about the relationship between angular velocities in rolling motion
  • Investigate the graphical representation of astroids and other related curves
Mathematicians, physicists, and engineering students interested in kinematics and the geometric properties of curves generated by rolling motion.
JanClaesen
I'm trying to describe the cycloid described by a wheel rolling inside a circle:
The (rotor)vector attached to the center of the rolling wheel is described by this equation:
w is the angular velocity of the wheel, e(x') and e(y') are the unit vectors and t is the time
This is the relative position vector of the point on the wheel that touches the big circle as the wheel rolls.
The origin of the absolute coordinate system x y is the center of the big circle, the origin (the center of the wheel) of the other coordinate system x' y' (where x' always stays parallel to x and y' to y) moves in a smaller circle with radius R - r, R is the radius of the big circle, r is the radius of the wheel. So the position vector of the origin in the absolute coordinate system is given by:
p = (R - r) cos( (r/R) w t)e(x) - (R - r) sin( (r/R) w t)e(y)
The angular velocity W of the smaller circle is given by (r/R)*w, since r*w = R*W (the wheel doesn't slip). The minus sign is because the wheel rolls clockwise.
r + p should describe the curve, now, when R = 4r I should plot an astroid, which is not the case, where have I gone wrong?
You have taken into account that it doesn't slip, but you haven't taken into account that the little wheel is additionally moving in a circle itself. So the amount the little wheel turns if the big wheel turns wt is (R/r)wt + wt. Try that.
