Is i squared equal to -1 or +1?
  • Context: Undergrad
  • Thread starter Thread starter brandy
The discussion revolves around the mathematical interpretation of the imaginary unit \( i \) and the expression \( i^2 \). Participants explore whether \( i^2 \) equals -1 or +1, examining the implications of square roots in the context of complex numbers and the rules governing exponentiation. The conversation touches on theoretical aspects, mathematical reasoning, and the properties of complex numbers.
  • Some participants assert that \( i^2 = -1 \) based on the definition of \( i \) as \( \sqrt{-1} \).
  • Others challenge the validity of the expression \( \sqrt{-1} * \sqrt{-1} = \sqrt{1} \) and note that the square root operation does not distribute over multiplication in the complex numbers.
  • It is mentioned that the property \( \sqrt{a*b} = \sqrt{a}*\sqrt{b} \) only holds for positive \( a \) and \( b \).
  • Some participants propose that mathematical rules can be defined to work with exponents while maintaining logical consistency, but the nature of these rules is debated.
  • There are discussions about the implications of squaring both sides of equations and the importance of considering the positive root in certain contexts.
  • A later reply introduces the concept of defining square roots using complex logarithms, suggesting that \( \sqrt{-1} \) could be interpreted as \( \pm i \) depending on the definition used.
Participants do not reach a consensus on whether \( i^2 \) can be interpreted as +1 or -1. Multiple competing views and interpretations of mathematical rules remain throughout the discussion.
Participants express uncertainty regarding the application of square root properties in complex numbers and the implications of defining operations in different mathematical contexts. The discussion highlights the limitations of applying real number rules to complex numbers without careful consideration.
brandy
i was taught that i2 = -1
because ((-1)1/2)2=(-1)2/2=(-1)1=-1
but isn't it mathematically correct to say
[tex]\sqrt{-1}[/tex] * [tex]\sqrt{-1}[/tex] = [tex]\sqrt{-1*-1}[/tex] = [tex]\sqrt{1}[/tex] = 1
what the heck!
Is there some bleedingly obvious thing I am missing.
Mathematics news on Phys.org
i^2=-1
Since
i=[tex]\sqrt{-1}[/tex]
No, it's not correct, and you just discovered why. Exponents don't work quite the same way in the complex numbers as they do in the reals. In the reals, that expression isn't valid because the left-hand side involves two numbers that are not real. In the complex numbers, the square root operation does not distribute over multiplication.
That particular property ([tex]\sqrt{a*b}=\sqrt{a}*\sqrt{b}[/tex]) only holds true if a and b are positive.
OK, so what mathematical rules can I define to work with exponents and still be on the safe side with logical truth?
[tex]i[/tex] is constructed as [tex](0,1) \in \mathbb R x \mathbb R[/tex]
[tex]i^2 = -1[/tex] and therefore that [tex]i = \sqrt{-1}[/tex]
follows directly from how algebraic operations are defined on that field. the rule you're talking about does not hold in [tex]\mathbb C[/tex]
logical truth... that is beyond the scope of mathematics. mathematics is a game of formal systems: axioms and rules of inference.
if you can construct a field where [tex]\sqrt{-1} \sqrt{-1} = 1[/tex] than it's perfectly mathematically valid...
just as it's mathematically valid that in [tex]\mathbb C[/tex], [tex]i^2= -1[/tex]
Here's another method that contains a fallacy:
1 = 1
(-1)^2 = 1^2
sqrt (-1)^2 = sqrt 1^2
-1 = 1
CheckMate said:
i^2=-1
Since
no... when you square a square root the number under the radical remains in tact. isquared is not 1s.
1 = 1
(-1)^2 = 1^2
-1 = 1
does line 1 have something to do with line 2?
and you forget the +- solutions for the square root...
[itex]1=1^2[/itex] and also [itex]1=(-1)^2[/itex] so yes, line 1 does have a little something to do with line 2.
No, the square root of a number is almost always defined as the positive value. [itex]\sqrt{9}\neq \pm 3[/itex], it only is +3.
However, when you solve [itex]x^2=9[/itex] then you need both positive and negative values. [itex]x=\pm (\sqrt{9}) =\pm (3) =\pm 3[/itex]
Which is what you are doing. You are saying:
(-1)^2 = (1)^2 which is true
operate on this as it were algebraic :
(A)^2 = (1)^2
A = +- Sqrt[1^2]
A = +- 1
Which are the two solutions to the first equation. I think you're not following proper operational methods by ASSERTING that you can raise each side without taking into consideration.
sqrt(-a)=sqrt[i2a]
sqrt[i2a]*sqrt[i2b] = (i*i)sqrt[a]sqrt= -(sqrt[ab])
(A)^2 = (1)^2
A = +- Sqrt[1^2]
A = +- 1
So you've shown that [itex]A=\pm 1[/itex]. Well, yes... substitute A back into it and you get:
[tex](\pm1)^2=(1)^2[/tex]
which is what we've already stated. I don't see what you're trying to get at here.
This is different to what you said earlier about having a [itex]\pm[/itex] solution when you take the square root.
The square root and other non-integer exponents can be defined using the complex logarithm, which is defined as the multivalued "inverse" of the complex exponential. Why multivalued? Note that we have
[tex]e^z=e^{z+i2\pi n}[/tex]
for any integer n. What's [itex]\log e^z[/itex] supposed to be? z? It can't be, since that would imply that
[tex]z=\log e^z=\log e^{z+i2\pi n}=z+i2\pi n[/tex]
for all n, which implies that all integers are zero.
We can avoid this problem by defining
[tex]\log z=\log(|z|e^{i Arg\ z})=\log |z|+i Arg\ z+i2\pi n[/tex]
The right-hand side should actually be interpreted as the set
[tex]\{\log |z|+i Arg\ z+i2\pi n|n\in\mathbb Z\}[/tex]
but it's too awkward to always use that notation. Note that when we take the logarithm of both sides of the first equation in this post, we get the same thing on both sides, so we have at least solved that problem.
Now we can define [itex]z^a[/itex] by
[tex]z^a=e^{\log z^a}=e^{a\log z}[/tex].
The square root is the special case a=1/2.
[tex]\sqrt z=e^{\frac 1 2 \log z}=e^{\frac 1 2(\log |z|+i Arg\ z+i2\pi n)}=\pm\sqrt{|z|}e^{\frac i 2 Arg\ z}[/tex]
So with this definition we get [itex]\sqrt{-1}=\pm i[/itex]. If we instead choose to define [itex]\sqrt z[/itex] as the single value [tex]\sqrt{|z|}e^{\frac i 2 Arg\ z}[/tex], we get [itex]\sqrt{-1}=i[/itex].
  • · Replies 16 ·
  • · Replies 34 ·
  • · Replies 20 ·
  • · Replies 27 ·
