Which ball will hit the ground first?
  • Thread starter Thread starter Idrees
    Ground
The discussion revolves around a physics problem involving two tennis balls thrown horizontally from a building at different speeds. The central question is which ball will hit the ground first, considering the effects of gravity and neglecting air resistance.
  • Participants explore the relationship between horizontal and vertical motion, questioning how horizontal velocity impacts the time to fall. Some suggest using projectile motion equations to analyze the problem, while others present differing interpretations regarding the effects of Earth's curvature.
The discussion includes various perspectives on the problem, with some participants providing insights into the physics involved. There is a recognition that both balls will hit the ground simultaneously under certain assumptions, although differing reasons for this conclusion are presented.
Participants are navigating assumptions about the Earth's shape and the neglect of air resistance, which may influence their reasoning. The original poster expresses uncertainty about the relevance of equations in this context.
Idrees
What hits the ground first??
If we simultaneously throw two tennis balls horizontally from the top of a building, one at 10 m/s and the other at 14 m/s. Neglecting the air resistance, which one will hit the ground first?
i don't think we use equations, but we have to consider the speed of each ball and how they are thrown horizontally??
I think the ball with 10 m/s should hit the ground first because it won't reach far and eventually fall vertically from the top of buliding ?? please help out??
They both start with a vertical velocity of 0.
Horizontal velocity does not affect vertical velocity.
You could also use equations of projectile motion to confirm this.
Technically, the 10 m/s tennis ball will hit the ground first, but not for the reason you mentioned.
It's because the Earth is round! The ground where the 14 m/s tennis ball impacts is just a few microns lower, so that ball has further to fall!
Otherwise, assuming flat Earth, they'd both hit at the same time.
Yes, considering the Earth is flat, they both will hit at the same time.
The one with an initial speed of 10m/s will travel a less distance and the one with an initial velocity of 14m/s will travel more, but they will take the same time.
You can verify this with this equation:
For motion on the y-axis:- h=uyt - 1/2gt2
since 'uy' is zero, the equation simplifies to:-
h= -1/2gt2
or, t=sqrt of (2h/g)
Since 'h' and 'g' are same in the case of both the balls, the time taken by each to reach the ground will be equal.
  • · Replies 38 ·
