Find the direction and magnitude of the resultant forces
The discussion revolves around determining the direction and magnitude of the resultant forces acting on an object, specifically involving two forces: one of 40 pounds along the positive x-axis and another of 25 pounds at an angle of 80 degrees to the x-axis.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore various methods to resolve the forces into components and calculate the resultant force. There are attempts to use trigonometric identities and vector addition, with some questioning the steps taken to arrive at certain expressions.
The discussion is active, with participants providing different approaches to the problem, including component separation and geometric interpretation. Some guidance on using the cosine and sine laws is mentioned, but no consensus on a final method or solution has been reached.
Participants are working under the constraints of homework guidelines, which may limit the use of certain methods or require specific rounding in their answers. There is also a noted confusion regarding the calculations leading to the proposed answers.
dancer1311
1. Two forces of magnitude 25 pounds and 40 pounds act on an object. The force of 40lb acts along the positive x-axis, and the force of 25lb acts at an angle of 80 degrees with the positive x-axis. Find the direction and magnitude of the resultant force. Round the direction and magnitude to the nearest whole number.
2. The answer is suppose to be direction: 29 degrees and magnitude 51lb
3. i thought it was suppose to be 65(cos30i + sin30j)
which got me 65[tex]\sqrt{}3[/tex] divided by 2 i plus 65 divded by 2
but this doesn't give me the correct answers.
From where you are reaching at "65(cos30i + sin30j)"?
<40,0> + <other force vector_x, other force vector_y> = ?
F1: 40 lbs, along x-axis
F2: 25 lbs, 80 degrees from x-axis.
Separating out the components, we have:
x-axis component = 40 + 25*cos(80) = 40 + 4.34 = 44.34 lbs
y-axis component = 25*sin(80) = 24.62 lbs
Net force = sqrt( x^2 + y^2) (you can do the math) and the angle is tan-1*(24.62/44.34).
Since both rootX and mugaliens divided into components, here is a direct way: draw the 25 lb force as starting at the tip of the 40 lb force and you have a triangle with sides of length 25 and 40 and angle between them 180- 80= 100 degrees. Use the "cosine law" to find the length of the third side, the magnitude of the resultant force, and use the "sine law" to find the angle that third side makes with the 40 lb force.
26K
  • · Replies 16 ·
  • · Replies 18 ·
