How Do You Calculate Rocket Motion Parameters Over Time?
The discussion focuses on calculating rocket motion parameters, specifically velocity, acceleration, and travel height as functions of time. The user assumes a constant exhaust velocity and a constant rate of mass change for the rocket. The derived equation incorporates the rocket's velocity (vr), exhaust velocity (ve), and the rate of mass change (dM/dt). Key considerations include the effects of changing weight due to gravity and drag during vertical motion.
  • Understanding of basic physics principles, particularly Newton's laws of motion.
  • Familiarity with rocket propulsion concepts, including exhaust velocity (ve).
  • Knowledge of calculus, specifically derivatives for calculating functions of time.
  • Experience with motion equations in a single dimension.
  • Study the Tsiolkovsky rocket equation for a deeper understanding of rocket motion.
  • Learn about the effects of drag on rocket flight, including drag coefficient calculations.
  • Explore numerical methods for simulating rocket motion over time.
  • Review NASA resources on rocket propulsion and motion for practical applications.
Aerospace engineers, physics students, and anyone interested in the dynamics of rocket motion and propulsion systems.
Dulle
Hi there
I'm having a bit trouble understanding the rocket motion and how the find the velocity, acceleration and travelheight as a function of time.
First, i assume that the velocity of the ejected mass relative to the rocket is constant. Secondly, i assume that the rocket mass changes with a constant rate. I'm working with the motion in a single dimension.
I have derived the rocket motion equation considering the acceleration of the rocket to be:
where vr is the velocity of the rocket, ve is the exhaust velocity, Mr is the mass of the rocket and dM/dt is the change in mass over the interval dt.
So - how do i find:
The velocity as a function of time
The acceleration as a function of time
The travelheight as a function of time
For vertical motion you'll need to account for changing weight w = -mg and the drag, and then if the engine burn is short consider the momentum during coasting flight.. Start here and be sure to visit the NASA link included:
https://www.physicsforums.com/showthread.php?t=199087
  • · Replies 47 ·
  • · Replies 42 ·
