Simple Harmonic Motion: Spring Motion
The discussion centers on calculating the spring constant of a silk thread used by a 2.1 g spider in simple harmonic motion. The spider achieves maximum amplitude when tapped at a frequency of 0.8 Hz, while the thread's resonant frequency is established at 8 Hz. The spring equation v = sqrt(k/m)*sqrt(A^2 - X^2) is referenced for determining the spring constant (k) in N/m. Understanding the relationship between frequency, amplitude, and spring constant is crucial for solving the problem.
  • Understanding of simple harmonic motion principles
  • Familiarity with the spring constant and Hooke's Law
  • Basic knowledge of oscillation frequency and amplitude
  • Ability to manipulate and apply the spring equation v = sqrt(k/m)*sqrt(A^2 - X^2)
  • Calculate the spring constant (k) using the provided mass and frequency values
  • Explore the effects of varying amplitude on oscillation frequency
  • Learn about resonance in mechanical systems and its applications
  • Investigate the relationship between mass, spring constant, and oscillation period
Students studying physics, educators teaching mechanics, and anyone interested in the principles of oscillation and spring dynamics.
TJC747
A 2.1 g spider is dangling at the end of a silk thread. You can make the spider bounce up and down on the thread by tapping lightly on his feet with a pencil. You soon discover that you can give the spider the largest amplitude on his little bungee cord if you tap at a frequency of 0.8 Hz. What is the spring constant of the silk thread?
(answer to be in N/m)
Certainly understanding the spring equation that states v = sqrt(k/m)*sqrt(A^2 - X^2)
But how to apply it? I'm clueless. Help would be appreciated. Thanks.
8 Hz is the thread's resonant frequency: the spider, if let alone at a point above the equilibrium point, would naturally oscillate at 8 Hz. This is because 8Hz taps would hit the spider at the same point in its swing every time, so the taps reinforce each other instead of cancelling.
