Buoyancy of ship, volume displaced, and tension of crane (in/out) of water
The discussion focuses on calculating the volume of water displaced by an 18,000 kg steel hull and the tension in the crane's cable during different states of submersion. The volume of water displaced is determined using the formula for buoyancy, which incorporates the density of steel (7.8 x 103 kg/m3) and water (1000 kg/m3). When fully submerged, the tension in the crane's cable is calculated to be 180,000 N, based on the hull's weight. The conversation highlights the importance of understanding buoyancy principles and the relationship between mass, density, and volume in fluid mechanics.
  • Understanding of buoyancy principles
  • Knowledge of density calculations
  • Familiarity with Newton's laws of motion
  • Basic grasp of fluid mechanics
  • Study Archimedes' principle and its applications in buoyancy
  • Learn about calculating tension in cables using static equilibrium
  • Explore the relationship between mass, density, and volume in various materials
  • Investigate the effects of shape and design on buoyancy in marine engineering
Engineers, physics students, and professionals in marine design or construction who need to understand the principles of buoyancy and tension in lifting heavy objects from water.
orbits
A crane lifts the 18,000kg steel hull of a ship out of the water.
The density of steel is known to be 7.8 x 103 kg/m3, while that of water is 1000 kg/m3.
A) While the steel hull is fully submerged in the water, what is the volume of water displaced by the hull? I really have no idea how to work this problem out.
Buoyancy = m* density * V displaced * G
m=pv
B) What is the tension in the crane's cable when the hull is fully submerged?
I believe this one is related to A
Density * Volume * G = F m=(density) Volume
1000* 18000/10 *10
f=1.8 x 107
C) What is the tension in the crane's cable when the hull is out of the water?
Ft= mg
Ft = 18,000 * 10 (class standard)
Ft= 180,000N
If you have the mass of the material and its density, can't you find its volume? That volume displace the same volume of water.
Only if the hull fills with water. If it does not, it displaces far more water than its own volume.
The question seems a bit tricky. It talks about a fully-submerged the hull, which, to me, strongly suggests that the hull has filled with water (unless it's a watertight submarine hull I suppose :-p).
So, I guess you're right. They're simply talking about the volume of the steel itself, not any kind of buoyant hull-shape.
  • · Replies 18 ·
13K
