Understanding the Kronecker Delta Symbol: A_j Explained
  • Thread starter Thread starter tony873004
    Delta Symbol
The discussion revolves around the Kronecker delta symbol and its application in summation notation, specifically in the context of manipulating expressions involving indexed variables such as \( A_k \). Participants are exploring the implications of summing over indices and the correct interpretation of the delta function in relation to these indices.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are examining the correct summation process involving the Kronecker delta, questioning the repeated index and its implications on the resulting expression. There are attempts to clarify the distinction between fixed and repeated indices in summation.
Some participants have provided insights into the summation convention and the role of the Kronecker delta, while others express confusion about the terminology and concepts being discussed. There is an ongoing effort to clarify these points without reaching a definitive conclusion.
One participant notes the absence of a textbook, relying solely on class notes, which may contribute to the confusion regarding the summation convention and the interpretation of the delta function.
tony873004
[tex] \begin{array}{l}<br /> \delta _{jk} A_k \\ <br /> \\ <br /> \delta _{jk} A_k = \left( {\delta _{1,1} + \delta _{1,2} + \delta _{1,3} + \delta _{2,1} + \delta _{2,2} + \delta _{2,3} + \delta _{3,1} + \delta _{3,2} + \delta _{3,3} } \right)A_k \\ <br /> \,\,\,\,\,\,\,\,\,\,\,\,\, = \left( {1 + 0 + 0 + 0 + 1 + 0 + 0 + 0 + 1} \right)A_k \\ <br /> \,\,\,\,\,\,\,\,\,\,\,\,\, = 3A_k \\ <br /> \end{array}[/tex]
But the answer should be [tex]A_j[/tex]. Where did I go wrong?
As far as I know, the sum is only over k, not j.
That's true, and you also need to recognize that [itex]A_k[/itex] has different values for different terms in the sum.
and to further add, the delta will only be 1 when k=j in the sum.
Sorry, I don't understand your explanations. We don't have a textbook for this, only class notes. So I don't even know what "the sum is over k" means. Is it possible to work out the example? Thanks!
The sum is always only over a repeated index, the other indices are fixed. For example suppose A is a 2x2 matrix and x is a 2-vector:
[tex]A_{ij} x_j = \sum_{j=1}^2 A_{ij} x_j = A_{i1} x_1 + A_{i2} x_2[/tex]
really your only problem is that you summed over j
Hi tony873004! :smile:
See http://en.wikipedia.org/wiki/Einstein_summation_convention" :wink:
No. As others have said, the sum is over k, the repeated index, not i.
[tex]\delta_{ik}A_k= (A_{i1}A_1+ A_{i2}A_2+ A_{i3}A_3[/itex]<br /> for every i. That is<br /> [tex]\delta_{1k}A_k= A_{11}A_1+ A_{12}A_2+ A_{13}A_3= A_1[/tex]<br /> [tex]\delta_{2k}A_k= A_{21}A_1+ A_{22}A_2+ A_{23}A_3= A_2[/tex]<br /> [tex]\delta_{3k}A_3= A_{21}A_1+ A_{32}A_2+ A_{33}A_3= A_3[/tex]<br /> That is, it is the vector [itex]<A_1, A_2, A_3>[/itex] which can be written as [itex]A_i[/itex] or [itex]A_j[/itex] as they mean the same thing.<br /> <br /> <br /> <blockquote data-attributes="" data-quote="" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> But the answer should be [tex]A_j[/tex]. Where did I go wrong? </div> </div> </blockquote>[/tex]
