Drawing a Force-Time Curve for a Changing Force and Calculating Final Momentum
  • Thread starter Thread starter gold123456th
    Curve Drawing
The discussion revolves around drawing a force-time curve for a scenario involving a body subjected to two different forces over time. The subject area includes concepts of force, momentum, and graphical representation in physics.
  • Participants discuss how to represent the transition between two forces on a force-time graph, questioning whether to connect the segments with a vertical line or to keep them continuous. There is uncertainty about the implications of drawing vertical lines on the graph and how to accurately depict the forces acting at the transition point.
The discussion is ongoing, with participants exploring different interpretations of how to accurately represent the forces on the graph. Some guidance has been offered regarding the continuity of the line, but there is no explicit consensus on the best approach to take at the transition point.
Participants are considering the implications of drawing vertical lines on the graph and the nature of the forces acting at the exact moment of transition, indicating a need for clarity on the definition of force application in this context.
gold123456th
A 1.0kg body initially traveling in the positive x-direction at 10m/s is acted upon for 2.0s by a force in that same direction of 20N. It then experiences a force acting in the negative direction for 20s equal to 2.0N. Draw a force-time curve and determine the final momentum
I drew the 20N curve and 2.0N curve in the same coordinate plan, but I don't know if I should connect them with a vertical line. If I do, then at t=2s, the force would be both 20N and 2.0N
You should be able to draw the curve in one line without having your pencil leave the paper. (A continuous line)
Draw the curve after the first 2s then keeping your pencil on the paper, draw the curve for the next 20s, so you should end up with a domain of [0,22].
But then a vertical line would be drawn. Can vertical lines appear on a force-time graph? Then t= 2.0s would have a lot of forces.
Hmmm... I don't think it makes much of a difference as to whether you draw the line or not.
The question states that there is a 20N force for exactly 2 seconds then IMMEDIATELY after there is a 2N force for 20s.
You could always draw your horizontal 20N line then have an exclusive point at 2s on both lines then continue on with your 2N line. Because the we don't really know what is happening exactly at 2 seconds.
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 42 ·
