How Do You Calculate the Temperature for a Hot Air Balloon to Lift Off?
  • Thread starter Thread starter slowhands
    Density Pressure
The discussion revolves around calculating the temperature required for a hot air balloon to lift off, given its volume, mass, and the density of surrounding air. The problem involves understanding the relationship between the density of air at different temperatures and the principles of buoyancy.
  • Participants discuss the formula relating density and temperature, with one participant attempting to apply it to find the temperature change needed for lift-off. Others question the assumptions made about density calculations and the conditions necessary for buoyancy.
Participants are exploring different interpretations of the problem, with some clarifying the relationship between the densities of air at different temperatures. There is an ongoing examination of the necessary conditions for the balloon to achieve lift-off, and guidance has been offered regarding the correct application of the density formula.
There is a noted confusion regarding the calculation of density and the assumptions about the relationship between the balloon's weight and the surrounding air density. Participants are also referencing previous equations related to volume and temperature changes.
slowhands
A hot air balloon has a volume of 1600m3. The balloon, its passengers, basket and other equipment have a mass of 500kg. Using the formula below, find the average temperature the air in the balloon must be raised to for it to lift off the ground.
Density of surrounding air = 1.3kgm-3.
[tex]\rho=\rho_{0}\dfrac{273}{273+\Delta T}[/tex]
where [tex]\rho[/tex] = new density, [tex]\rho_{0}[/tex] = original density
[tex]\rho=\dfrac{Mass}{volume}[/tex]
so
[tex]1.3=\dfrac{500}{1600}(\dfrac{273}{273+\Delta T})[/tex]
[tex]4.16=\dfrac{273}{273+\Delta T}[/tex]
[tex]1135.68 + 4.16\Delta T = 273[/tex]
[tex]\Delta T = -207.375[/tex]
But then this means the temperature change is negative which can't be right... Can anyone help please?
You tried to use 500/1600, which I assume was supposed to be 500kg/1600m^3, as a density. It's not. That's simply the mass of the basket and people divided by the volume of the balloon. To compute a density, you have to divide the mass of an object by the volume of the same object.
But anyway: that's not what the equation is meant to represent. The densities [itex]\rho[/itex] and [itex]\rho_0[/itex] are densities of air at two different temperatures. If you like, you can think of it this way: the product of density and temperature (in Kelvins) for air is a constant. So the value of that product at 273K,
[tex]273\mathrm{K}*\rho_0[/tex]
is equal to the value at some higher temperature [itex]273\mathrm{K}+\Delta T[/itex],
[tex]273\mathrm{K}*\rho_0 = (273\mathrm{K}+\Delta T) * \rho[/tex]
In this problem, you're trying to find [itex]\Delta T[/itex]. That means you'll need to get the other variables in the equation from other sources. [itex]\rho_0[/itex] is the density of air at [itex]273\mathrm{K}[/itex], which you're given. [itex]\rho[/itex] is the density of air at the higher temperature. It needs to be the right density so that the balloon as a whole will float. How would you figure out what that is?
The new density of the air in the balloon has to be less than or equal to the surrounding air for the balloon to float, right? But I don't know how you could work out how much less than 1.3kgm-3 it has to be... Would you need to use
[tex]V=V_o(1+\dfrac{\Delta T}{273})[/tex]
We were given this in a previous question
Not less than or equal to - strictly less than, by at least some amount. Remember that the balloon has to float despite the weight of the basket and people (and the balloon itself) pulling it down. If the density of the air in the balloon were equal to the density of the outside air, how could it float? (It couldn't)
Surely you're familiar with the concept of buoyancy? Buoyant force?
9K
