Which Is More Powerful: 2 Piston or 4 Piston Engines?
  • Thread starter Thread starter otomanb
    Engine Piston
The discussion revolves around the comparative power of 2 piston versus 4 piston engines, particularly in the context of motorcycles. Participants explore various factors influencing engine performance, including cylinder capacity, engine type (2-stroke vs. 4-stroke), and other design considerations.
  • Some participants suggest that the power of an engine depends significantly on the capacity of the cylinders, indicating that high power can be achieved with either 2 or 4 cylinders depending on design.
  • Others argue that 2-stroke engines are generally more powerful than 4-stroke engines due to their firing mechanism, where each cylinder fires every crank revolution.
  • Several participants highlight that many other variables, such as tuning, gearing, size, and weight, also play crucial roles in determining engine power and speed.
  • One participant humorously notes that the question is pointless without considering these additional factors, comparing it to the color of the bike.
  • A later reply acknowledges a misunderstanding regarding the engine types, clarifying that the original question was interpreted differently.
  • Some participants emphasize that while 2-stroke engines can be more powerful, there are also many powerful 4-stroke engines, suggesting that the answer ultimately depends on specific circumstances.
Participants do not reach a consensus on which engine type is definitively more powerful, as multiple competing views remain regarding the influence of various factors on engine performance.
The discussion highlights the complexity of engine performance evaluation, with limitations in assumptions about engine design and the need for specific context when comparing different engine types.
otomanb
suppose a bike which has 2 piston engine and other is 4 piston. which one is most powerful?
thanks
Depends on the capacity of the cylinders - you can build high power 2 cylinders and low power 4 cylinders.
Other than that it's a design decision.
2 cylinders are smaller and simpler, 4 cylinders allows a smaller capacity/cylinder so they can move faster and so rev higher.
Bikes painted red are always faster than bikes painted yellow.
Unless the yellow ones have noisier exhausts
Code:
what is the reason behind that?
let me explain in different manner,
A bike of 100CC with 4 stroke engine
a bike of 100 cc with 2 stroke engine
Now which will be more powerful and fast
otomanb said:
Code:
what is the reason behind that?let me explain in different manner,
The one where the driver only ate half his burger for lunch.
It's a totally pointless question, as it relies on so much more than how many cylinders it has. Tuning, gearing, size, weight etc etc etc.
Indeed, there are far many more variables than number of cylinders and capacity, making yours an impossible question to answer (hence my comment about colour). If you have a quick look round here there are some excellent posts on all the things which go into engine power output and vehicle speed.
2 stroke engines are generally more powerful than 4 stroke engines...
Oh, I really fail. I'm sorry OP you changed and clarifired the question, but I just read it as 2 cylinder 100cc not 2 stroke.
2 strokes are more powerful because each cylinder fires every crank revolution, as opposed to firing once every 720 deg in a 4 stroke. EDIT: In general.
But it's a generalisation, there are plenty of four stroke engines more powerful than two strokes of the same capacity.
The answer is: "It depends".
  • · Replies 56 ·
  • · Replies 45 ·
  • · Replies 58 ·
