Calculating semester gpa? did my school make a mistake?
The discussion centers around the calculation of semester GPA and cumulative GPA for a premed student, who is concerned about discrepancies between their own calculations and the school's reported GPA. The conversation explores the implications of GPA calculations, including rounding and truncation methods, and the significance of minor GPA differences in the context of medical school admissions.
  • Meta-discussion
  • One participant calculated their semester GPA as 3.6 and cumulative GPA as 3.89, while the school's reported values are 3.59 and 3.88, respectively.
  • Questions arise regarding whether the school's software rounds or truncates GPA values, with some participants suggesting that truncation could explain the discrepancy.
  • There is uncertainty about the value assigned to an A- grade, with some suggesting it could be 3.7 points while others argue it might be 3.67 or another value.
  • Some participants express that a difference of 1/100 of a point in GPA is unlikely to significantly impact medical school admissions, emphasizing other factors like letters of reference and personal interviews.
  • Concerns are raised about the fairness and implications of plus/minus grading systems, with some suggesting it may be a response to grade inflation.
  • One participant suggests contacting the school to verify the accuracy of the GPA calculations, while others note that the AMCAS system will recalculate GPAs for medical school applications, potentially mitigating the issue.
Participants express differing views on the significance of minor GPA discrepancies and the methods used for GPA calculation. There is no consensus on the exact cause of the discrepancy or the best course of action to address it.
Participants highlight the potential variations in GPA calculation methods across different institutions and the impact of these differences on medical school applications. There is also mention of the uncertainty surrounding the specific grading policies of the participant's school.
sportsstar469
ok i know ill come off as a smart *** here..but I am a premed major, and I am dealing with very stiff competition. every single point on my gpa means a lot to me. with that being said this semester i didnt do so hot. i got an A- in a 4 credit biology course, a B in a 4 credit math course, and an A in a 5 credit chemistry course.
i calculated my semester GPA to be a 3.6 and my cumulative gpa to be a 3.89. i went onto the site where my grades are posted and it said that my semester gpa is a 3.59. once again i know this sounds stupid, but its important to me. am i in the wrong here? its also saying my gpa is a 3.88.
Does the school's software round numbers or truncate numbers?
Is an A- worth 3.7 points? It's kind of hard to truncate 3.60 into 3.59. None the less, it's almost certainly because of the software they use to calculate GPA's. The last significant digit is always uncertain (which is why they go through all the trouble to teach you sig figs at the beginning of all your freshman math/science courses).
Premed is a major?... I thought you were majoring in "science."
im not sure what trunctuate means, but i don't know if they do either. my cumulative gpa they might round to the nearest 2 decimals though since my cumulative is 3.88 and my semester is 3.59. however its strange that both my cum and semesters gpa are exactly 1/10 less than on the goa calc site i used for this,.
Truncating means cutting the digits off after 2dp so, for example, 3.5879 becomes 3.58. Rounding means taking account of the last digit you cut off, so 3.5879 becomes 3.59.
It's likely that this is the difference, or you have calculated your results by rounding at an earlier stage in your calculation.
1/100 of a point in your GPA is NOT going to make a difference. Letters of reference and personality on an interview is going to have more impact than that tiny difference in GPA. And, when it's time to apply to med schools, your GPA at your school actually becomes meaningless, because you'll completely recalculate it to normalize the numbers on the AMCAS forms. The reason is that not all schools use the same grading scales. While you earned an A-, there are places that don't give minus grades, and an A- would have been either an A or a B+ or maybe even a B.
The handling of plus grades and minus grades can vary, too. If an A- is worth 3 and 2/3 points, then the school calculated your GPA correctly. If they used 3.7, then your semester GPA would be 3.6.
If you used a website's calculator to calculate your GPA, do you know how your school calculates GPA? There's no guarantee the website uses the same method.
I can understand your concern. Results from all these different schools, that used different methods to calculate their GPA, will be combined into one ordered list and your results ranked against the others.
Just like football. A player runs the ball out of the endzone, a referee estimates where the ball was when the player was tackled and plants a stake. Then, after four plays of eyeballing where the ref thinks the ball should be place, they measure how far away the ball is from that original spot with great preciseness. If the ball comes up just a wee bit short, they lose the game even though no one ever knew exactly where the ball should have been spotted for any single play!
Just try not to be the guy on the cutoff line. By time you're splitting people that finely, it's just luck and they may as well flip a coin as to who gets admitted and who gets rejected. Other than that, you're worrying yourself over fine details that you only have a rough control over.
yeah, its just a 3.6 looks so much better for a term than a 3.59. and i still get paranoid about ever ounce of my gpa, because a lot of students are so competitive that adcoms looks at all things. its my break though, so I am going to get in some doctor shadowing, and maybe plan for next semes.
i don't understand the reasoning for +/- grades. is it a response to grade inflation (hey, I'm old, it was an issue like 20 years ago) to inject more competition into the process now that overall grades are higher?
i think its to make things fair. if you have somebody with an 89.5 average and someone with a 100 average, and they both get an A, its hard to tell who has really mastered it.
i think usually, those who master the material are excellent at most things they do, and their overall GPA will differentiate that ethic after 4 years.
Sportsstar, I don't blame you for being worked up over this. Medical school admission is indeed a stressful and extremely competetive process. First of all, you might want to talk to someone at your school and make sure they didn't just screw up. It's hard to believe that this would happen, given that it's all computerized. But the phone call is free and should only take five to ten minutes, so why not?
Secondly, as Moonbear already mentioned, AMCAS recalculates your GPA anyway. So even if your school has a weird way of calculating GPA that puts you at a disadvantage, this will ultimately not matter, because the GPA that medical schools see is your AMCAS GPA. You might want to check out this PDF document:
http://www.aamc.org/students/amcas/amcas2010instructions080409.pdf
These are the instructions for AMCAS 2010. On page 7 you'll find all of the information about how AMCAS calculates your GPA.
yes, but if you have someone consistently getting 89.5s, and someone consistently gettin 100s in their classes, and they each have the same 4.0 gpa, it will be hard to see whos mastering the material enough to get 100s, and who has a good grasp to get an 89.5, but not exactly brilliant enough to get the 100 score. I am kind of on the fence about plus or minuses. on one hand, if a studenmt receives an 87 in the class, they will receive an A- which is a benefit, because they other wise would have got a B with no plus or minuses. on the flip side however, if you have an 89.5, instead of getting the A you will get screwed and get the a min.
thnks man i appreciate this. i actually checked another calculator, that had the same results as my school.
That's an easy system.
At the one school I knew that used pluses and minuses, it took a 93 for an A (and there was no A+). 90-92 was an A-. 87-89 was a B+. 83-86 was a B 80-82 was a B-, etc.
Whether an 89.5 got you an A in the old system or an A- in the new system depended entirely on the professor. Some professors rounded up to the nearest integer. Some rounded up to the nearest 10th, etc. Some would even truncate, meaning an 89.9997 was just an 89.
  • · Replies 26 ·
