Lagrangian Mechanics: Pendulum & Trolley
The discussion revolves around the application of Lagrangian mechanics to a system consisting of a simple pendulum attached to a trolley. Participants explore the formulation of the Lagrangian using generalized coordinates, specifically the position of the trolley and the angle of the pendulum. The focus includes the kinetic and potential energy terms involved in the system.
  • Some participants question why the kinetic energy (KE) of the trolley is represented as 1/2M\dot{x}^{2} instead of 1/2M(\dot{X}+\dot{x})^{2}, suggesting that the trolley should be affected by the pendulum's motion.
  • Others clarify that the KE of the trolley depends solely on its own speed, \dot{x}, and not on the pendulum's velocity, which is indirectly related through the generalized coordinates.
  • There is a discussion about the potential energy (PE) term, with some participants unsure why it is expressed as mgY instead of mg(l-Y), indicating a need for clarity on reference points for potential energy calculations.
  • Some participants emphasize that the Lagrangian must account for both the trolley and the pendulum as a system of particles, suggesting that relative coordinates may not suffice for accurate representation.
  • There is acknowledgment that the choice of reference point for potential energy can affect the formulation of the Lagrangian, with some suggesting that any point in the laboratory frame could be used.
Participants express differing views on the dependence of the trolley's kinetic energy on the pendulum's motion, leading to an unresolved debate about the correct formulation of the Lagrangian. There is also uncertainty regarding the appropriate reference point for potential energy calculations.
Participants note that the choice of reference point for potential energy can lead to different formulations of the Lagrangian, highlighting the importance of context in these calculations. Additionally, the discussion reveals a reliance on generalized coordinates and the implications of using relative versus absolute positions in the system.
ian2012
Hi, Hope someone can help me clear up this question. I know the answer but I am unsure of the reasoning behind it, so here it is:
Question:A simple pendulum of mass m and length l hangs from a trolley of mass M running on smooth horizontal rails. The pendulum swings in a plane parallel to the rails.
(a)Using the position x of the trolley and the angle of inclination θ of the pendulum as generalised coordinates, show that the Lagrangian may be written as
[tex]L=\frac{1}{2}(M+m)\dot{x}^{2}+ml\dot{x}\dot{\theta}cos\theta+\frac{1}{2}ml^{2}\dot{\theta}^{2}+mglcos\theta[/tex]
Answer:Use [tex]X=lsin\theta[/tex] and [tex]Y=lcos\theta[/tex] as the Cartesian coordinates of the pendulum relative to the trolley.
[tex]L=\frac{1}{2}M\dot{x}^{2}+\frac{1}{2}m[(\dot{X}+\dot{x})^{2}+\dot{Y}^{2}]+mgY[/tex]
And the answer falls out when you follow this through...
I don't understand why the first term is [tex]1/2M\dot{x}^{2}[/tex]
and not [tex]1/2M(\dot{X}+\dot{x})^{2}[/tex]. And I also don't understand why the last potential energy term is only [tex]mgY[/tex] and not [tex]mg(l-Y)[/tex]?
Would appreciate if someone could help me out on this, or if there is an easier way to go about the answer! Many thanks!
That first term is just the KE of the trolley.
Measured from a reference point at the top of the pendulum, V = -mgY.
Yes I am aware that it is the KE of the trolley. Why isn't the trolley displaced by the pendulum? Since the pendulum is displaced by the trolley? Shouldn't there be an extra displacement term in the KE of the trolley.
ian2012 said:
Then why isn't the trolley displaced by the pendulum? Since the pendulum is displaced by the trolley?
Any displacement of the trolley will be reflected in a change in its position x. The KE of the trolley depends only on the speed of the trolley, which is given by [itex]\dot{x}[/itex].
The second term, the KE of the pendulum depends on the velocity of the trolley, whereas the first term, the KE of the trolley, has no dependence on the velocity of the pendulum. How is this possible since a movement of the pendulum will also affect the trolley? I don't understand why the logic breaks down here.
No, the KE of the pendulum depends only on the velocity of the pendulum. Since your coordinates are x and θ, the horizontal position of the pendulum is given by x + Lcosθ and is thus indirectly dependent on the position of the trolley. The speed of the pendulum only indirectly depends on the speed of the trolley, since Lcosθ is with respect to the trolley. Since the position of the trolley is one of the generalized coordinates, the KE of the trolley only depends on [itex]\dot{x}[/itex].
Two things:
1. Remember, the Lagrangian is for a system of particles, not just one so that
[tex]L=\sum (T-U)[/tex]
i.e. you have to include BOTH the trolley and the pendulum into the calculation.
2. When dealing with a system of particles, I don't believe using relative coordinates suffices.
Just to be clear: I'm not saying that the motion of the pendulum is independent of the motion of the trolley. Not at all. All I'm saying is that in terms of your chosen coordinates, the KE of the trolley is fully specified by [itex]1/2M\dot{x}^{2}[/itex].
The coupling of the motion comes in when you specify the KE of the pendulum (which includes [itex]\dot{x}[/itex]) and in applying the Euler-Lagrange equations.
I understand your reasoning and it makes sense now, thanks.
For the PE term of the answer, how would one know to use the reference point as the top of the pendulum instead of the position of the mass m?
Any point in the laboratory frame will do as a reference for specifying gravitational PE, since only changes in PE are physically significant. Here we measure the position of the mass m with respect to the top of the top of the pendulum in order to specify its PE, but we could just as well measure its position from the lowest point of the pendulum.
But you can't take the position of the mass itself as a reference point--for one thing, the mass is accelerating; for another, its the PE of that mass that we are trying to specify.
Yea, sorry I meant the lowest point of the pendulum as the reference point. Yeah sure that makes sense. Then the Lagrangian will be different depending on the reference point taken. One will have to spot from the question to take the reference point from the top of the pendulum.
