Searching for a particular kind of convergent sequence
  • Context: Graduate
  • Thread starter Thread starter A-ManESL
    Convergent Sequence
The discussion revolves around finding an example of a complex sequence that converges to 0 but does not belong to the space ℓ^p for any p ≥ 1, specifically focusing on the divergence of the series \(\sum |x_n|^p\).
  • Exploratory, Mathematical reasoning, Debate/contested
  • One participant requests an example of a complex sequence (x_n) that converges to 0 but is not in ℓ^p for p ≥ 1.
  • Another participant suggests that the sequence \(x_n = \frac{1}{\log(n+1)}\) might work, although they have not verified the divergence for p > 1.
  • The same participant expresses confidence in their suggestion but encourages others to explore the necessary estimates for proving divergence without relying on obscure series tests.
  • A third participant indicates difficulty in establishing the divergence and asks for more explicit guidance.
  • A fourth participant proposes that for divergence, the inequality \((\frac{1}{\log(n)})^p > \frac{1}{n}\) holds for sufficiently large n.
Participants have not reached a consensus on the example of the sequence or the method for proving divergence, indicating ongoing exploration and differing viewpoints.
Some assumptions about the behavior of logarithmic functions and their implications for convergence and divergence are present but not fully explored or resolved.
Mathematicians and students interested in sequence convergence, functional analysis, and properties of ℓ^p spaces may find this discussion relevant.
A-ManESL
I want an example of a complex sequence [tex](x_n)[/tex] which converges to 0 but is not in [tex]^p[/tex], for [tex]p\ge 1[/tex] i.e. the series [tex]\sum |x_n|^p[/tex] is never convergent for any [tex]p\ge 1[/tex]. Can someone provide an example please?
I suspect 1/log(n+1) will work, but I haven't checked divergence for p > 1.
*EDIT* I'm fairly certain it works. I'll let you figure out the estimates needed to demonstrate divergence (hint: you don't need obscure series tests).
I am having trouble establishing the divergence. Can you be more explicit? Thanks.
For divergence I would guess (1/log(n))p > 1/n for sufficiently large n.
  • · Replies 17 ·
