Speed C is Dependant Upon Source?
  • Context: Graduate
  • Thread starter Thread starter omin
    Source Speed
The discussion revolves around the nature of the speed of light, particularly whether it is dependent on the source from which it originates. Participants explore concepts related to reflection, acceleration, and the behavior of light in various contexts, including relativity and interactions with mirrors.
  • Some participants assert that the speed of light is constant and not determined by its source.
  • There are claims that light's behavior during reflection involves absorption and re-emission, rather than a change in speed.
  • Questions are raised about whether a mirror acts as a new source of light and how this relates to the speed of light.
  • Some participants argue that light does not accelerate in the conventional sense and maintains a constant speed of c.
  • Concerns are expressed about the implications of light's behavior in a gravitational field and how this affects its momentum and frequency.
  • A participant questions the assumptions made in relativity demonstrations regarding the direction of light and its momentum during reflection.
  • There is a discussion about the energy transfer when light strikes a mirror, with some suggesting that absorbed energy contributes to heating rather than re-emission of photons.
Participants generally agree that the speed of light is constant, but there are multiple competing views regarding the implications of reflection, the role of mirrors, and the nature of light's interaction with sources. The discussion remains unresolved on several points, particularly concerning the mechanics of reflection and the behavior of light in different contexts.
Some claims rely on specific assumptions about the behavior of light and the definitions of terms like "speed" and "acceleration." The discussion includes unresolved questions about the nature of light's interaction with mirrors and the effects of gravitational fields on light.
omin
1. The speed of light is constant.
2. Light may reflect off objects.
3. The speed of light is not determined by it's source.
If the speed of light is constant and this speed is unaffected by it's source, then the expression, the shape light is, is it's natural shape and it's speed simultaneously. Light's inertia is it's shape, it's physical expression and vice versa. Light speeds itself, objects don't speed the light.
But, light can be reflected. For something to change directions, acceleration must occur. For acceleration to occur, a change in velocity must occur. For velocity to occur, a change of speed and/or direction must occur. Can it be proven that only direction occurs when light is reflected? What rules out a change of speed assuredly during reflection? Is a mirror that reflects light a new source compared to the source where light last emerged?
If the source does not determine the speed of light, then why does the speed of light always acclerate away from a source at the speed of light consistently? How does the light know that the source is there to speed away from at the constant speed?
If two mirrors are traveling at different speeds compared to each other and light is reflected from one to another, shouldn't now light change speed dependent upon source or what happens?
Since light is constant, it must have an exact quantity between the mirrors at any given state, and this quantity of light definitely changes with the distance the mirrors are from each other. When the mirror's distance is compressed, where does this extra light go? Does it begin to reflect faster?
-Still trying to understand relativity.
So far, so good.
To be blunt, this makes no sense. What is the shape of light, and why do you think that this shape is identical to the inertia of light?
All you have to do is measure the speed of the incident beam and of the reflected beam. In every case, you'll find that they are the same. Actually, this has nothing whatsoever to do with relativity. If you bounce a tennis ball off a rigid wall, and the collision is elastic, then the speed of the tennis ball will be the same before and after the collision.
Yes it is, because the photons are absorbed and re-emitted by the mirror.
You've just answered your own question: The very fact that the light always moves (not accelerates) away from the source at the speed of light consistently is precisely why we say that the source does not determine the speed of light. That's what it means for the speed of light to be independent of the speed of the source.
It doesn't know anything.
No, it shouldn't. You said it yourself, the speed of light is independent of the speed of the source.
What "exact quantity" are you talking about?
When a photon is reflected from a surface, it is not actually stopped and turned around. Instead, it is absorbed, and a new photon is emitted in the opposite direction.
- Warren
- Warren
Ah, you beat me to it. :cry:
Sounds like someone needs to brush up on their relativity.
To put a finer point on what warren said:
Light doesn't accelerate in the way you think it does. It doesn't change speed. It doesn't slow down to a stop, then reverse its course. It is absorbed and re-emitted, and never travels at any speed other than C.
No acceleration. Photon's are forbidden to travel at any speed other than c.
Note: A photon can accelerate in a gravitational field.
Pete
Note: That is why light changes frequency. Doppler affect.
Pete
The direction light is traveling can and will change in a gravitational field, thus an acceleration, but the magnitude of the velocity will remain a constant c.
light momentum
Perhaps someone can answer this related question. In the original 'train with mirror' relativity demonstration the traveller supposes his light to travel perpendicular to the train whilst the observer sees it travel a triangular path,from which the time relations are derived.
The hidden assumtion is that the DIRECTION of light has changed with the source ( not it's speed).
There then arises a question -- if light is absorbed by a mirror and then re-emitted it is assumed that it's momentum did not change ( hence the angle of reflection and reception are equal )
But in the above scenario the momentum did change -- so the question is does a moving mirror have equal angles or not ?
- Warren
Is the above true?
When light strikes a mirror, almost all of it is reflected, a small amount is absorbed but it would only heat the mirror and not emit photons.
the energy of the oscillating electrons does not go back to the light. The energy instead goes toward increasing the motion of the atoms, which causes the material to heat up.
Microsoft® Encarta® Reference Library 2002. © 1993-2001 Microsoft Corporation. All rights reserved.
What does your quote have to do with the reflection of light on mirrors? All your quote is doing is taking chroot's explanation a little further by saying a very small amount is not reemitted and heats up the mirror.
chroot, how exactly is a photon absorbed and a new photon emitted in the opposite direction?
That's not entirely accurate; all of it gets absorbed, and then almost all the energy is reemitted.
You have to be careful to distinguish between the macroscopic and microscopic terms.
Right, some momentum is imparted to the mirror itself.
Yes, the angles are equal.
When the photon is absorbed it exerts a force equivalent to all of it's energy. Then according to Newtons laws for every action (force on the mirror) there is an equal and opposite reaction, this being the emission of another photon in the opposite direction. Then when the mirror uses its own momentum to create a new photon in the opposite direction. I don't want to confuse the mircoscopic with the macroscopic but this is the same principle that causes a ball will bounce off a wall instead of just stopping once it hits the wall.
So, photons are created by momentum? How is that possible?
Well not exactly. You see since it absorbed the first photon it needs to exert an equal and opposite force back on to the photon. But since the photon is no longer there (it was absorbed) it simply emits a photon in the opposite direction. But photons do have momentum if that's what you mean.
No, what I meant is what you previously said.
How is a photon created in that process? If the photon is not created, where does it come from?
stupid makes a good point. u say that the photon gets totally absorbed then a new photon is made from the mirror? that doesn't make sense... or are u saying that the mirror absorbs the photon then emits it?
and if the mirror absorbs the photon and emits it then doesn't that mean the photon had to be slowed down, then accelerated in the opposite direction?
It makes plenty of sense. It's quantum mechanics at work (have you not taken chemistry?). A photon is incident on an atom. The atom absorbs the photon (IOW, the photon is destroyed) and an atomic electron is promoted to a higher energy level. The resulting state is unstable, and it quickly decays. In the decay, a new photon of the same wavelength is created and emitted.
E=mc^2
You can turn matter into energy and vice versa, so you can change a photon into momentum and momentum into a photon.
Thank you for explaining, Tom. I thought matter or energy could not be created nor destroyed? Yes, I have taken chemistry. I owned at chemistry! I'm taking Chemistry II AP this coming school year. So the excitation of an electron causes decay. What kind of decay is this called? When an electron goes into decay it produces photons? Is that the only product of this decay?
The photon isn't destroyed, it's absorbed.
Well, Tom told me it was destroyed. Wouldn't the conversion from momentum to energy or mass involve something other than [itex]E=mc^2[/itex]? Like maybe [itex]E=pc[/itex], since light is theorized to have no rest mass? Or would you just use the whole total energy equation if you were to convert a photon to mass?
tom, yes i have taken chemistry (i posted that in the thread u so graciously ended) and I've know how a photon is produced, but thanks for the reiteration. for the mirror to make a whole new photon, that means the other photon was destroyed and that doesn't make sense because everyone knows that energy cannot be created or destroyed. but u, mr. mattson said that the photon gets destroyed. and entropy says that the mirror creates a new photon, which also doesn't make sense. quote me if u must, but the description u're giving for this process contradicts what einstein said..
ABOSRBED, not destroyed. You know that's what he meant.
and EMITTED, not created. Same Reason.
how am i supposed to know what someone meant, alkatran? u told me that when we discussed that equation. mattson said destroyed and entropy said created. there's a difference...
"Creating" a photon might as well be the same as "emitting" one, except that emitting better represents what is actually happening. Now, if he said "a photon is confused by the mirror" we would have a similar situation to the disregards of PEDMAS in said equation.
Where does this newly emitted photon come from, if it travels in the opposite direction of the absorbed photon?
  • · Replies 36 ·
  • · Replies 53 ·
  • · Replies 29 ·
  • · Replies 57 ·
  • · Replies 33 ·
  • · Replies 42 ·
  • · Replies 18 ·
  • · Replies 24 ·
