Using Conservation of Energy to Find Friction Coefficient
The problem involves a 2.00 kg block on a rough incline connected to a spring, with the goal of finding the coefficient of kinetic friction. The block moves down the incline before coming to rest, and the setup includes considerations of gravitational potential energy, spring potential energy, and frictional forces.
  • Participants discuss the application of conservation of energy, questioning how to account for energy losses due to friction. There are attempts to equate initial gravitational potential energy with final spring potential energy and energy lost to friction.
Some participants have offered alternative approaches and observations regarding the direction of forces and the nature of the coefficients of friction. There is an ongoing exploration of the assumptions made in the calculations, particularly concerning the work done by friction and the correct application of angles in the equations.
Participants note potential confusion regarding the distinction between static and kinetic friction coefficients, as well as the implications of the block's movement on the forces acting on it. There is also mention of the need for clarity on the mechanical energy transformations involved in the problem.
312213
A 2.00 kg block situated on a rough incline is connected to a spring of negligible mass having a spring constant of 100 N/m. The block is released from rest when the spring is unstretched, and the pulley is frictionless. The block moves 0.204 m down the incline before coming to rest. Find the coefficient of kinetic friction between the block and incline.
http://img692.imageshack.us/img692/9474/physicsam.jpg
Final position is used as 0 height.
http://img694.imageshack.us/img694/2420/physicsm.jpg
The way I see the forces is that Fs and Ffric acts in one direction and Fgsin37 opposes it.
Fs+Ffric=Fgsin37
kx+u(mgcos37)=mgsin37
100(0.204)+u((2)(9.8)cos37)=(2)(9.8)sin37
u=-0.55
Coefficient came out negative so this approach won't work.
For the most part, I don't understand how to approach this problem. What does it seem like I don't understand?
Fs+Ffric=Fgsin37
u=-0.55
If you are going to use the conservation of energy why don't you use all the mechanical energy you have before the mass is released. and set that equal to all the mechanical energy after plus the "loss" of mechanical engergy due to friction as thermal energy.
If the plane was frictionless the mass would be displaced further down the plane as one way to view it, yes? Then it seems to me you can figure out the normal force on the block. And the force of static friction can be figured using the energy/work. Then you have mu? This is a cursory observation of the situation that I believe will work.
I think the title of your question said using the conservation of energy? So maybe you start off with all GPE to begin with and end with spring pot. energy 1/2k(x^2) and heat(due to friction)... does this stuff strike you as familiar?
Ui=Kf+Usf+Ef
mgh=0+1/2kx²+E
(2)(9.8)(0.204sin37)=(1/2)(100)(0.204)²+E
0.3255J=E
The nonconserved energy is the work of friction so
W=(Ffric)rcos37
0.3255=u((2)(9.8)cos37)(0.204)cos37
u=0.128
(0.12763323293335829568080338705843)
Does the nonconserved energy convert to mu like that?
That looks good. BTW, what the two different results suggests is that your assumption about the direction of the frictional force at the new equilibrium is wrong. In other words , it is working to oppose the block being pulled back up the incline. That the magnitude of 0.55 is also wrong suggests that the static and kinetic cooefients are different--since you were asked to find the kinetic coefficient, your second approach was the right one.
The work seems to have worked correctly up until the part of
W=(Ffric)rcos37
One of those cos37 shouldn't be there. Which is it? Or are either acceptable to be there, so long as only one is?
W=(Ffric)rcos37
That last cos 37 is not correct. W_f = F_f . d = uN(d)cos alpha, where alpha is the angle between the friction force and displacement vectors, alpha = ?
  • · Replies 33 ·
  • · Replies 34 ·
  • · Replies 16 ·
  • · Replies 36 ·
