Planetary Motion,Feynman Lectures
The discussion focuses on calculating the path of a planet around the sun using Newton's laws of dynamics, specifically referencing Feynman's Lectures on Physics, Volume 1, Chapter 9, Section 9-7. The initial conditions set by Feynman include x=0.5, y=0, v(x)=0, v(y)=1.63, and e=0.1. Participants analyze the significance of the value 1.63 for v(y), concluding that it is critical for forming a perfect elliptical orbit. The value of v(y) is shown to depend on the initial x value, with a decrease in x leading to a decrease in the required v(y) for stable motion.
  • Understanding of Newton's laws of dynamics
  • Familiarity with gravitational force equations, specifically F = -G*M*m/r^2
  • Basic knowledge of elliptical orbits and parameters such as semi-major axis (a) and semi-minor axis (b)
  • Proficiency in numerical methods for simulating planetary motion, particularly using programming languages like C++
  • Study the derivation of orbital velocities in elliptical motion using Newton's laws
  • Learn about the conservation of angular momentum in planetary motion
  • Explore numerical integration techniques for simulating planetary orbits
  • Investigate the relationship between initial conditions and orbital stability in celestial mechanics
Students of physics, astrophysicists, and anyone interested in computational simulations of planetary motion and dynamics based on classical mechanics.
@run
This question is a part of independent study.
The problem is based on Feynman lectures volume 1,chapter 9,Newton's laws of dynamics,section 9-7 planetary motion. To compute numerically path of motion of a planet around sun using Newtons laws of kinematics and gravitation Feynman took initial conditions as x=0.5,y=0,v(x)=0,v(y)=1.63 & e=0.1.I understand that v(x)=0 and v(y) should have some value initially,but cannot understand why he take the value 1.63 for v(y) and how he computed 1.63.
F = -G*M*m/r^2
r=sqrt(x^2+y^2)
x=x(0) + e* v(x) , v(x) = v(0) + e*a(x) , a(x) = -x/(r^3)
y=y(0) + e* v(y) , v(y) = v(0) + e*a(y) , a(y) = -x/(r^3)
Two attempts are made
.x = a cos $, y = b sin $ -------(1)
v(x) = -a(d$/dt) sin $ -------(2),
v(y) = -b(d$/dt) cos $ = -(bx/a)(d$/dt)--------(3)
y = 0 means $ = 0, x=a.
so, v(y) = -b(d$/dt) = -bw
now there is a relation connecting the parameters a,b and e of an ellipse
b*b = a*a(1-e*e).
taking e = 0.8(a guss) value of b is calculated.
If I can calculate w in some way, i can get v(y). Some attempts made using the w*r^2 is conserved.
But couldn't calculate w.
2.
This attempt is made first for understanding that v(y) = 1.63 have any importance.
A simple program in c++ is made and plotted x-y graph.This analysis revealed that 1.63 have importance,then only perfect ellipse will be formed. If v(y) is taken as 0.8 planet will not revolve
around sun,the same thing happens when a value greater than 1.63 is taken ,for example 2.2
Analyis also says that the value of v(y) depend on x.When i take x=1 ,v(y) should have a value
near 1.4.This can be expect naturally because when x value changes from 0.5 to 1 the
gravitational force decreased,so less v(y) required.
So it can be concluded that v(y) depend on initial x value. But how feynman computed the value 1.63 remain a mystery.
  • · Replies 27 ·
  • · Replies 38 ·
