Deciding if the series converges or diverges
  • Thread starter Thread starter Lord Dark
    Series
The discussion revolves around determining the convergence or divergence of the series Sum(k=1,infinity) (2009+5^(-k^3))/(k^2(1+e^(-k^2))). Participants are exploring various tests and comparisons related to series convergence in the context of mathematical analysis.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts a comparison test and expresses uncertainty about the next steps after their initial analysis. Some participants question the choice of constants in the comparison and the reasoning behind ignoring certain terms in the inequality.
Participants are actively engaging with the problem, with some providing insights into the comparison test and clarifying the inequalities involved. There is a mix of interpretations and approaches being discussed, but no explicit consensus has been reached regarding the convergence of the series.
There are indications of confusion regarding the application of the comparison test and the handling of terms in the series. The original poster has noted previous attempts with the ratio test and k-th term test, which did not yield clear results.
Lord Dark
Hi everyone ,, got the following question
first I think it diverges so I did a comparison which is :
ak = (2009+5^(-k^3))/(k^2(1+e^(-k^2)))
e^(k^2))/(5^(k^3)*k^2) which is less than ak ,,
but now what should I do ?? which test should I use to make it diverges (that is if it diverges)
note : I tried already ratio test and it didn't work and k-th term but I get (infinity over infinity) so it's no use ,, can someone help please
It should be easy to see that
[tex]\frac{2009+ 5^{-k^3}}{1+ e^{-k^2}}< 2010[/tex]
compare this series to [itex]\sum 2010/k^2[/itex].
Thanks, jgens, for catching the typo.
lol ,, first of all ,, can you explain it a little further ,, how can you choose a number where the function is less than it ( i mean 20010) how did you know that number ??
and why did you remove 5^(-k^3) and e^(-k^2) ?? do they cancel each other or what ?
Halls mistyped and probably meant that
[tex]\frac{2009 + 5^{-k^3}}{1 + e^{-k^2}} < 2010[/tex]
This inequality should be obvious since [itex]5^{-k^3} < 1[/itex] which implies that [itex]2009 + 5^{-k^3} < 2010[/itex]. Now, because [itex]1 + e^{-k^2} > 1[/itex] we know that
Now, use the comparrison test as Halls suggested.
aha ,, now I got you ... thanks :)
  • · Replies 17 ·
