Proof of Connectedness of A and B in Topological Space X
  • Thread starter Thread starter madness
    Proof Topology
The problem involves proving that two closed non-empty subsets A and B of a topological space X are connected, given that both their union A ∪ B and intersection A ∩ B are connected.
  • The original poster attempts a proof by contradiction, questioning the nature of disconnected sets and their properties. They express confusion over the implications of A being both open and closed.
  • Some participants clarify the definition of connectedness and provide counterexamples to challenge the original poster's reasoning.
  • There is a discussion about the necessity of using all given assumptions in the proof, with participants suggesting that the original poster reconsider their approach.
The discussion is ongoing, with participants providing clarifications and counterexamples. There is no explicit consensus, but guidance has been offered regarding the definitions and assumptions involved in the proof.
Participants note the importance of understanding the definitions of connectedness and the implications of the properties of closed sets in the context of the problem.
madness
Let A, B be closed non-empty subsets of a topological space X with [tex]A \cup B[/tex] and [tex]A \cap B[/tex] connected.
Prove that A and B are connected.
A set Q is not connected (disconnected) if it is expressible as a disjoint union of open sets, [tex]Q = S \cup T[/tex]
I'm trying a proof by contradiction.
By the above definition, a set which is not connected must be open (is this really true?). So start by assuming A is disconnected, ie [tex]A = C \cup D[/tex] for C, D open and disjoint. Then A must be open, but should also be closed. Now consider [tex]A \cup B = C \cup D \cup B[/tex] and [tex]A \cap B = C \cup D \cap B[/tex]. I want to to arrive at a contradiction. The given properties are that A is both open and closed, B is closed, C and D are open and disjoint and [tex]A \cup B = C \cup D \cup B[/tex] and [tex]A \cap B = C \cup D \cap B[/tex] are connected. This all seems very complicated.
No, thankfully this isn't true. The set [tex][0,1] \cup [2,3][/tex] is disconnected and closed. The definition of connectedness requires S and T to be relatively open; that is, open in the subspace topology induced on Q. Keeping this in mind, an equivalent definition of disconnectedness of a subspace Q is that there exist disjoint open sets S and T such that [tex]Q \subset S \cup T[/tex] and [tex]Q \cap S \neq \emptyset \neq Q \cap T[/tex]. The subset relation shere removes your concern about disconnected sets being open.
Ah right instead of saying "a set is not connected if..." i should have said "a topological space is not connected if...". Hmm does this mean the rest of my reasoning was wrong? I have to replace my C's and D's with intersections over X.
Ok so thanks to the push in the right direction I seem to have solved it. However I didnt use the fact that A and B or closed or that [tex]A \cup B[/tex] is connected. It was done entirely on the fact that [tex]A \cap B[/tex] is connected. Could this be right?
No, that's certainly not true. A counterexample is given by [tex]A = (1,2) \cup (2,3)[/tex] and [tex]B = [2,3)[/tex]. Here [tex]A \cup B = (1, 3)[/tex] and [tex]A \cap B = (2, 3)[/tex] are connected, but A is not connected. Also, you should try to think of a very simple example that shows that neither A nor B must be connected even it [tex]A \cap B[/tex] is.
Yeah it took me a while to realize what I missed. I showed that if A is disconnected then [tex]A \cap B[/tex] is expressible as a union of disjoint open sets, but I need to show that they are non-empty sets.
Yup. Generally homework-style questions don't give you more assumptions than you need, so if you haven't used some/most of your assumptions, you should examine your proof. This heuristic will take you far in math.
  • · Replies 17 ·
