| Thread Closed |
Cheapest way to produce electricity |
Share Thread | Thread Tools |
| Jan5-10, 12:26 PM | #1 |
As we know there are different methods are used in different countries to produce power. What do you think which one near you is the most cheapest way to produce power.
Thanks |
| Jan5-10, 09:58 PM | #2 |
Mentor
Coal power is generally the cheapest for large-scale generation.
| Jan5-10, 10:14 PM | #3 |
Recognitions:
Complicated question.
Depends on the market, do you need a large central plant that can run for years, or a plant that can handle quick changes in load. What lifetime are you considering the capital cost over - and what interest rate are you paying. what politics are involved in getting different kinds of plant approved in your country? What fuel sources do you have. If you have coal then coal is cheap - but the plants are big and expensive. If you have natural gas then that's cheap and the plants are quick and cheap to build. If you don't have fossil fuels and your government/people are sane then nuclear is cheap. Once you've built the plant, then hydroelectric is cheapest to run. |
| Jan6-10, 06:49 AM | #4 |
near me using natural resources like coal and petrol for the generation of Electricity is not so good bcaz they are present in limited amount. I think wind and tidal way is very cheap and almost free running cost, what do u say?
in coal there is a big problem where to dispose off Coal's ash |
| Jan6-10, 06:58 AM | #5 |
| Jan6-10, 07:02 AM | #6 |
Cheap energy. I would invest into nuclear.
Cheers |
| Jan6-10, 12:16 PM | #7 |
| Jan6-10, 12:17 PM | #8 |
@ mheslep
for wind the source will be wind. very interesting question. Maintenance cost is not so high bcaz no fuel involve & no wast disposal problem. Nuclear is also a very very cheap way to produce power as well but i hope USA will not get against.
| Jan6-10, 12:45 PM | #9 |
Are we talking about renewable energy?
Wind is probably the cheapest, but only if you build it on a large scale. Solar, for example, is a fixed amount of energy for a unit area of radiation collection. The energy available from wind goes up with the square of the captured area and with the cube of the wind velocity. So 10mph winds have 8x the available energy as 5mph, and a rotor with a 100 foot radius has 100x the available energy as a rotor with a 10 foot radius. The fixed costs with wind would be the tower construction and the fabrication process. After that, if you can build one large enough you can harness huge amounts of energy in the right location. If you are interested in building your own wind turbine I have put together a tutorial on how to do it, along with links of it in operation and how to carve your own blades. It is here. |
| Jan6-10, 12:57 PM | #10 |
As of 2006, least to most expensive, in the US To Build, assumes no backup power ($ per kW): Natural Gas Combustion Turbine $670 Natural Gas Combined Cycle $730 Wind $1750-2400 Coal $2080-2740 Solar Thermal $3150-5700 Nuclear $3500-7000, Biomass $3500 Solar PV $8100 To Operate and Maintain only, per unit energy generated (cents / kWh) Solar Thermal (1), Wind (1.7 ), Solar PV (4.1) , Hydro Nuclear (3-4 cents, 2015 est) Coal () Natural Gas (2-3X coal) Levelized Cost: Build and Operating costs combined (cents / kWh) Coal 7.5 Gas Combined Cycle 8.6 Gas Turbine 17 Nuclear 13 in 2016 Edit: adding in actual O&M costs as I find them. http://www.psc.state.fl.us/utilities...2008_11_24.pdf |
| Jan6-10, 01:34 PM | #11 |
Recognitions:
Sorry I didn't phrase it very well.
Meant to say IF you have coal then thats cheap but IF you have natural gas fields then thats cheap. The economics of the stations is also a factor. coal = big expensive to build, gas = stations are quick and cheap to build. So it also depends on the timeframe and what you are paying as an interest rate. |
| Jan7-10, 04:53 PM | #12 |
Also, solar thermal and wind power have very low operating costs. Has this been definitively established? The way those numbers read, solar thermal and wind power have the potential to drastically lower electricity costs. Is there any proof that this has actually happened? Last I checked paying for green energy was much more expensive than the dirty alternative. I would love cheap and clean energy, but I have yet to actually see it. |
| Jan7-10, 06:31 PM | #13 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Cheapest way to produce electricity
| Can I produce electricity by using permanent magnets with no moving parts? | Electrical Engineering | 20 | ||
| Cheapest trailer in the world? | General Discussion | 1 | ||
| Nanogenerators Produce Electricity from Running Rodents | Mechanical Engineering | 0 | ||
| I want to buy a new Ti-89 titanium, but I don't know where is the cheapest | Calculators | 6 | ||
