Calculating Boat's Movement: Rates of Change with Rope Pulling on Pier
  • Thread starter Thread starter HeyHow!
    Change
The problem involves a man pulling a boat towards a pier using a rope, with the setup forming a right triangle. The height from which the rope is pulled and the distance of the boat from the pier are given, along with the rate at which the rope is pulled.
  • Participants discuss the use of the Pythagorean theorem and implicit differentiation to relate the rates of change of the triangle's sides. Some express uncertainty about how to proceed with the differentiation and solving for the rate at which the boat moves towards the pier.
There is ongoing exploration of the mathematical relationships involved, with some participants providing guidance on setting up the equations. However, there is no explicit consensus on the final steps to solve for the rate of change.
Participants note the absence of certain details, such as the force exerted on the rope, but clarify that the problem is primarily mathematical in nature. The specific values for the triangle's dimensions and the rate of rope pulling are provided.
HeyHow!
A man standing on a pier pulls a small boat towards him using a rope attached to the prow. The rope is pulled from a height of 2.4m above its point of attachment to the boat. The rope is pulled at a rate of 30 cm a minute. At what rate is the boat moving towards the pier when it is 3.2m away.
Im stuck on this problem. I know it is a right angled triange, and that you have to differentiate using phythagoras, but i am stuck. help appreciated please
yeah i think your going the right direction i'll just look it up for you
it dosn't happen to tell you the force being exerted on the rope? (in newtowns?)
no, is a maths question :smile:
yeah it is possible to do it by phythagorius
lol. Make a right triangle with legs of length 2.4 m for the vertical leg(x), and 3.2 m for the horizontal leg(y), with z as the hypotenuse or the length of the rope. Set up your equation as:
[tex]x^2 + y^2= z^2[/tex]
now make all of your variables (x,y,z) a function of time, so when you implicitly differentiate the equation with respect to time, it will look like this:
[tex]2x \frac{dx}{dt} + 2y \frac{dy}{dt} = 2z \frac{dz}{dt}[/tex]
now you know that dx/dt is constant, since the dude holding the rope isn't moving up and down, but is holding it steady while he pulls it in, so dx/dt cancels to zero. Just solve for dy/dt since that is the rate of change of the horizontal leg of the triangle (the rate is the boat moving towards the pier). y, z and dz/dt are all given in the problem. Plug'n solve.
greatly appreciated, but can't get dy/dt. any help please? :frown:
It's really just a matter of algebra now. Just get what you want on the left, and everything else on the right, and plug in what you know.
[tex]\frac{dy}{dt} = \frac{z}{y} \frac{dz}{dt}[/tex]
now for z, the problem told you that you wanted the value of dy/dt, when the boat was 3.2 m away. So z is just the square root of (3.2)^2 + (2.4)^2
(Pythag). dz/dt is the rate of change of z in time, which the problem gave you as "30 cm a minute."
:smile:
  • · Replies 21 ·
27K
9K
11K
