Why is the Injective Operator in L^2(0,1) One-to-One?
  • Context: Graduate
  • Thread starter Thread starter Carl140
    Injective Operator
The discussion revolves around the injective nature of an integral operator defined on the space L²(0,1). Participants explore the conditions under which the operator K is one-to-one, specifically addressing the implications of Kx(t) = 0 leading to x(t) = 0.
  • One participant defines the integral operator K and questions why it is "obvious" that K is one-to-one, seeking clarification on the condition Kx(t) = 0 implying x(t) = 0.
  • Another participant requests the use of LaTeX for clarity and points out a potential error in the integration variable.
  • A subsequent post corrects the integration variable, confirming the limits of integration are from s=0 to s=1.
  • A participant discusses the properties of L²(0,1) as a Hilbert separable space, introducing the Legendre polynomials as a basis and outlining the approach to prove that x must equal zero if Kx = 0.
  • The same participant applies the dominated convergence theorem and derives expressions involving derivatives of the kernel function k(s,t) to show that integrals of the form ∫₀¹ sⁿ x(s) ds = 0 for all n.
  • From the derived integrals, the participant concludes that the coefficients x_n = must be zero for all n, leading to the conclusion that x = 0.
Participants generally agree on the mathematical framework and steps involved in proving the injective nature of the operator, but there is no explicit consensus on the initial claim of K being "obvious" as one-to-one, as it is still under discussion.
The discussion includes assumptions about the properties of the integral operator and the application of the dominated convergence theorem, which may not be universally accepted without further clarification or proof.
Carl140
Hi!
Define an integral operator K: L^2 (0,1) -> L^2(0,1) by:
Kx(t) = Integral[ (1+ts)exp(ts)x(s) ds from t=0 to t=1].
Why is "obvious" that K is a one-to-one operator?
I know K is one to one if Kx(t) = 0 implies x(t) = 0 but I don't see why this is true. Can you please explain why?
Please use Latex. Do you mean the following? (you wrote 'from t=0 to t=1' while s is your integration variable)
[tex]Kx(t)=\int_0^1 (1+ts)\exp(ts)x(s)\mbox{d}s[/tex]
Yes, sorry about that. It is from s=0 to s=1.
[tex]L^2(0,1)[/tex] is a Hilbert separable space with inner product
[tex]<u,v> = \int_0^1 uv dx[/tex]​
and the set of Legendre polynomials is a Hilbert base of [tex]L^2(0,1)[/tex]
[tex]P_n (x) = \frac{\sqrt{2n+1}}{ 2^{n+1/2} n!} \frac{d^n}{dx^n} \left[ (x^2 - 1)^n \right] \; \; , \; n = 1,2,3,...[/tex]​
It mean
[tex]\forall v \in L^2(0,1) , v = \sum_{n=1}^{\infty} v_n P_n[/tex]​
where [tex]v_n = <v, P_n>[/tex].
Now we assume [tex]x \in L^2 (0,1) \, , \, Kx = 0[/tex] and try to prove that [tex]x = 0[/tex].
First put [tex]k(t,s) =(1+ts)\exp(ts)[/tex], by applying the dominate convergence theorem, we have
[tex]\frac{d}{dt} \int _0^1 k(s,t) x(s) ds = \int _0^1 \frac{\partial}{\partial t}k(s,t) x(s) ds[/tex]​
and further we have
[tex]\frac{d^n Kx}{dt^n} (0) = \left. \left( \frac{d^n}{dt^n} \int _0^1 k(s,t) x(s) ds \right) \right|_{t= 0}= \int _0^1 \left. \left( \frac{\partial^n}{\partial t^n}k(s,t) \right) \right|_{t=0} x(s) ds \;\;\; (1)[/tex]​
by applying the induction principle we get
[tex]\frac{\partial^n}{\partial t^n}k(s,t) = [(n+1)s^n + ts^{n+1} ] \exp(ts) \; ,\; \forall n = 1,2,3,... \;\;\; (2)[/tex]​
Combining (1)(2) and assumption Kx = 0, we get then
[tex]\int_{0}^{1} s^n x(s) = 0 \; , \; \forall n = 1,2,3, ... \;\;\; \;\;\; (*)[/tex]​
From [tex](*)[/tex] we have
[tex]x_n = <x, P_n> = 0 \; ,\; \forall n = 1,2,3,...[/tex]​
finally
[tex]x = \sum_{n=1}^{\infty} x_n P_n= 0[/tex]​
  • · Replies 0 ·
