Solve Ideal Gas Problem: Net Work of Cycle
  • Thread starter Thread starter daisyi
    Gas Ideal gas
The discussion revolves around an ideal gas problem involving a thermodynamic cycle. The original poster describes a cycle consisting of isothermal expansion, heating at constant volume, isothermal compression, and isobaric return to the original state. The goal is to find the net work done during this cycle.
  • Mixed
  • The original poster attempts to calculate the work done in each segment of the cycle using appropriate formulas for isothermal and isobaric processes. Some participants question the calculations and the assumptions made regarding volumes and signs of work.
Participants are actively discussing the calculations and interpretations of the work done in each part of the cycle. Some guidance has been provided regarding the signs of work and the need to verify the final volumes used in calculations. There is no explicit consensus on the final net work value, as different interpretations and calculations are being explored.
There are indications of potential rounding errors and misinterpretations of the final volumes used in the calculations. The original problem statement does not specify the expected format for the answer, leading to varied interpretations of the net work.
daisyi
Okay, I've been working on this for a while:
Three-tenths mole of an ideal gas at 400K is expanded isothermally from a pressure of 5x10^5 N/m^2 to 1.5x10^5N/m^2. If the gas is then heated to 500K at constant volume and then is compressed isothermally back to 5x10^5 N/m^2, and then isobarically back to the original condition, find the net work of the cycle.
I understand the whole concept of expanding and contracting, but combining the ways that these happen is very confusing to me.
first i found the volume for the first part using the formula V = nRT/P.
so for the first part, when its expanded isothermally i used the formula:
w = nRTln(V2/V1)
w= (3/10)*(8.314)*(400)*ln(6.65*10^-3/2*10^-3)
= 1198.68
same for the second isothermic expansion, except the temperature changed to 500, and therefrore the volume changed and:
w = -1503.58
then for the third part, i used the formula for isobaric gas:
w = P(V2 - V1)
= 245
Then for the net work, I added everything together, and got -364.8
What am I missing here??
Thanks!
If you have a set temprtature and pressure, the volume is
also determined for an equal amount of gas. So, if at the
end you get the original condition - all of the same parameters,
what kind of energy difference = work, are you looking for ?
it just says find the net work. I stated the problem exactly as it is written. Grr...this one is driving me nuts!
w = nRTln(V2/V1)
= 1198.68
Looks good. (You are defining work as work done by the gas on the environment. So + work means that energy is leaving the gas. That's OK. Just be aware that some define work as work done on the gas.)
w = -1503.58
Take a second look at this one. I suspect you are using the wrong final volume.
daisyi - if you add up all your work terms again, you'll see it will not give you -365. The calculation for all the individual work terms are correct, except for some rounding errors. When I did the calcuations I get: 1201.18 - 1501.47 + 249.42 = -50.87 or -50 after rounding.
one more thing...
I never got to this step in my previous post:
w = P(V2 - V1)
= 245
It's an isobaric compression: the work will be negative.
And yes, as PureEnergy points out, you did add your terms incorrectly. But that's not the real problem. :smile:
I double checked and it still looks right to me. This is how I did it.
V = nRT/P
so, when the gas is heated to 500k with constant volume, the volume is:
V1 = (3/10)(8.314)(500)/1.5x10^5
= 8.314x10^-3
and then when the pressure is compressed back to 5x10^5:
V2= (3/10)(8.314)(500)/5*10^5
= 2.49x10^3
I then plugged that into the equation w = nRTln(v2/v1) to get the 1198.68
V = nRT/P
Right.
= 8.314x10^-3
No. V1 = (3/10)(8.314)(400)/1.5x10^5 (You know the temp and pressure before it's heated.)
= 2.49x10^3
Right.
Doc's right, the third step should be negative so the net work is around -550.
