Solve Problem With L'Hospital's Rule
  • Context: Undergrad
  • Thread starter Thread starter Moose352
The discussion revolves around the application of L'Hospital's rule to demonstrate a limit involving the derivative of a function. Participants explore different approaches to show that the limit of the difference quotient equals the derivative of the function at a point.
  • Homework-related
  • One participant expresses difficulty in applying L'Hospital's rule to the limit problem.
  • Another participant presents an alternative proof using the definition of the derivative, showing that the limit can be derived without L'Hospital's rule.
  • A third participant acknowledges the alternative proof but mentions issues with signs during their own attempt.
  • A fourth participant suggests using the chain rule to derive the limit, leading to a different expression involving the average of the derivatives at points x+h and x-h.
Participants present multiple approaches to the problem, with no consensus on the necessity of L'Hospital's rule. The discussion remains unresolved regarding the best method to demonstrate the limit.
Some participants' approaches depend on the definitions of derivatives and the properties of limits, which may introduce assumptions about the function f and its differentiability.
Moose352
Having a very hard time solving this problem:
Use L'Hospital's rule to show that
[tex]\lim_{h\rightarrow0}\frac{f(x+h)-f(x-h)}{2h}=f^{'}(x)[/tex]
Thanks.
I can prove it without using l'hopital rule
we know that f'(x) =lim as h->0 (f(x+h) - f(x) / h) by definition
and also f'(x) = lim as h-> 0 (f(x) - f(x-h) /h )
if we add both of them we get 2(f'(x)) = (f(x+h) - f(x) + f(x) - f(x-h) ) / h
2(f'(x)) = (f(x+h) - f(x-h) ) / h
divide by 2 on both sides
f'(x) = (f(x+h) - f(x-h) ) / 2h
Thanks for the solution. In fact, I did the same thing, except in the other way. But the signs were not working for some dumb reason, dumb stuff kept cancelling out.
Just use the chain rule:
[tex]\frac{d}{dh}f(x\pm h)=\pm f'(x \pm h)[/tex]
so you get
[tex]\frac{f'(x+h)+f'(x-h)}{2}[/tex]
then take the limit as h goes to zero.
  • · Replies 18 ·
