Limit of ∑ k/n^2 from k=1 to n as n Approaches Infinity
  • Thread starter Thread starter ƒ(x)
    Series
The discussion revolves around evaluating the limit of the sum \(\sum k/n^2\) from \(k=1\) to \(n\) as \(n\) approaches infinity, within the context of calculus and limits.
  • Mixed
  • Participants explore the computation of the sum, with some suggesting the use of the formula for the sum of natural numbers and others discussing the application of L'Hospital's rule. There are questions about the validity of using L'Hospital's rule for integer values of \(n\) and alternative methods for evaluating the limit.
Several methods have been proposed, including the use of L'Hospital's rule and basic limit properties. Participants are engaging in a dialogue about the appropriateness of different approaches, with some expressing a preference for more elementary methods. There is acknowledgment of multiple interpretations and methods being discussed.
There is a mention of constraints regarding the application of L'Hospital's rule to sequences defined by integers, as well as the nature of the problem being a multiple-choice question.
ƒ(x)
If n is a positive integer, then the limit of [tex]\sum k/n^2[/tex] from k=1 to n as n approaches infinity = ?
A) pi
B) 1
C) 1/2
D) 1/pi
E) 0
How do I do this?
c) 1/2
since 1/n^2 is constant remove it outside
sum of n natural numbers formula can be used for the summation
then you have lim tending to infinity
n(n+1)/(2n^2)
use L 'opital
should be right
payumooli said:
c) 1/2
n(n+1)/(2n^2)
use L 'opital
should be right
Except that, technically, L'Hospital's rule does not apply since n is given to have integer values. Just divide the numerator and denominator by n2 and use basic properties of limits.
If a sequence of functions, f(x), has limit L as x goes to a, then any sequence, {f(xn)}, with {xn} converging to a, must also converge to L. In particular, if f(x) goes to L as x goes to infinity, the sequence {f(n)} also converges to L. As long as a function of n, for n a positive integer, can be as a function of x, a real variable, (for example, does NOT involve factorials), L'Hopital's rule can be applied.
Yes, of course. That's why I said "technically". Still, I think it is best if students learn to use the more elementary methods when they are appropriate.
personally i wouldn't prefer L opital either
Thanks, the answer is C. But, is there another way to do this?
You have been given two methods. Did you understand both? An experienced person doing a multiple choice question where you didn't have to show work or give a reason would have would just have looked at the ratio of the n2 terms to get the answer.
