If Electrons Repel Each Other, Then
  • Context: Undergrad
  • Thread starter Thread starter Gravitron
    Electrons Repel
The discussion revolves around the apparent contradiction between the repulsive nature of electrons as described by Coulomb's Law and the attractive interactions observed in molecular formations, particularly in water. Participants explore the reasons behind molecular attraction despite the repulsion of electrons, addressing both theoretical and practical implications.
  • One participant questions how water molecules, which consist of electrons that repel each other, can attract to form a stable molecule.
  • Another participant suggests that the attractive force between atoms arises from a balance of forces at a certain distance, where the attraction from the nucleus to the electrons outweighs the repulsion between electrons.
  • It is proposed that water molecules act as dipoles, with positive and negative charge concentrations that can attract each other when aligned properly.
  • A different perspective emphasizes that electron shells seek to be filled, leading to shared electrons between hydrogen and oxygen atoms, resulting in stable molecular formation.
  • One participant corrects an earlier claim about superconductors, stating that even in superconductors, electrons still repel each other, and their pairing is facilitated by external interactions rather than a cessation of repulsion.
Participants express differing views on the mechanisms of molecular attraction and the role of electron repulsion, indicating that multiple competing explanations exist without a clear consensus.
Some claims rely on specific definitions of energy states and molecular interactions that may not be universally accepted. The discussion includes assumptions about electron behavior in various states of matter, which are not fully resolved.
Gravitron
I am not sure if this is an appropriate area for this topic, so please re-direct if necessary.
As I understand it, according to Coulomb's Law, Electrons should repel each other (except under certain circumstances such as super cooled as in a superconductor) However, I am having a hard time tying this together with observations of daily life. Perhaps someone might better explain the reasons. Here are a few examples:
1) Water molecules are made up of two hydrogen and one oxygen atom, all of which have electron fields. Why and how can they "attract" to one another to create the molecule in the first place?
2) Understanding that the first question may yield an answer of "there are different energy levels for each one when they meet" or something similar, what about water molecule with water molecule? They would consist of the same combination of atoms/electrons, and therefore carry identical energy states, so why does water have such an affinity (attraction) to water?
3) Obviously water is not the only substance that has an affinity towards itself, so I am a bit confused.
Thanks for any replies and assistance with this question.
G
1.) Because there's a distance between the atoms where the energy is minimized. At that distance the nucleus' attraction to the other atoms electrons results in a greater attractive force than the repulsion from just the electrons.
If you were to plot the energy vs. distance of the atoms it would be something like this: http://filer.case.edu/pal25/image.jpg . There would be a bond for energy < 0.
2.) Your second point is because a water molecule is itself a dipole. So you can think of the molecule as having a positive charge concentration at one location and a negative charge location a little distance away.
So if you have two water molecules the positive of one dipole and the negative of another dipole would be attracted if they were aligned properly.
What I think you're looking for is why a hydrogen atom (which is surrounded by -ive electrons) and an oxygen atom (which is also surrounded by -ive electrons) would attract.
Here's the nutshell: Electron shells like to be filled, and will share electrons with other atoms to do so. This makes them stick together.
The first, innermost electron shell of every atom can hold 2 electrons. The next outer shell can hold 8 electrons.
Hydrogen has only one electron (in order to be electrically neutral: same # of +s as -s); its electron shell is filled when there are two electrons in it. So, despite being electrically neutral, its normal state has a sort of an electron "hole" that wants to be filled.
Oxygen has 8 electrons (electrically neutral with same number of +s as -s). These 8 electrons are distributed with 2 in the inner shell and 6 in the outer shell. The outer shell needs 8 to be filled. That leaves it with a sort of 2 holes.
If 1 oxygen and 2 hydrogen atoms are put near each other and given a little bit of a kick (such as a spark or flame), they will very happily get together and share their 8 electrons. This leaves each H and the O with effectively-filled shells. This state is low energy, meaning it will take a fair bit of energy (such as an electric current) to tear them apart again.
And I should also correct this. Even in a superconductor, the electrons STILL repel each other. Their ability to form bound pairs is NOT because they stop repelling each other, but it is due to all the surrounding ions of the solid that produced the "glue". In other words, a gas of free electron would not be able to form such bound pairs without an external help (either via phonons, or external magnetic fields).
Zz.
  • · Replies 20 ·
  • · Replies 36 ·
  • · Replies 38 ·
14K
