Radial acceleration and gravity
This discussion clarifies the relationship between radial acceleration and gravitational acceleration for objects in circular motion, specifically in the context of a ferris wheel. When an object is at the lowest point of the wheel, its radial acceleration, which can equal gravitational acceleration (g), does not negate the object's overall acceleration. Instead, the total acceleration comprises both radial and tangential components, and they should not be added together as they act in opposite directions.
  • Understanding of circular motion kinematics
  • Familiarity with concepts of radial and tangential acceleration
  • Basic knowledge of gravitational acceleration (g)
  • Ability to analyze forces acting on an object in motion
  • Study the principles of circular motion and centripetal acceleration
  • Learn how to calculate radial and tangential acceleration in various scenarios
  • Explore the effects of gravitational forces on objects in circular motion
  • Review examples of motion in a vertical circle, particularly at different points of the path
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of objects in circular motion, particularly in relation to gravitational forces.
chudd88
This is a very basic question, and not specific to one single homework assignment, but general to many similar types of problems.
If an object is moving in a wheel (like a ferris wheel), I understand how to determine its radial acceleration. But if a problem simply asks for the objects "acceleration", and doesn't specify radial acceleration, does this imply that the radial acceleration vector should be added to the acceleration due to gravity?
For example, when the object is at the lowest point on the wheel, its radial acceleration is directed entirely upward, while the acceleration due to gravity is entirely downward. If the radial acceleration happens to be "g" at that point, would this mean that the object is experiencing no acceleration? It seems intuitive, but it could easily be counterintuitive.
Thanks.
-Dan
No, you don't add the acceleration due to gravity to anything. The acceleration at the bottom is whatever it is. If the wheel is rotating, then there will be an upward radial acceleration which you can obtain in the usual manner (from the kinematics of circular motion). That's that.
Note that at any point in its motion, the object may have both a tangential and a radial component of acceleration.
10K
  • · Replies 18 ·
