Line integral around an ellipse
The discussion revolves around evaluating the line integral \(\int_{\gamma} xy \, dx + x^2 \, dy\) for two specific cases involving the curve defined by \(2x^2 + 3y^2 = 8\). The first case considers the lower half of the curve from (2,0) to (-2,0), while the second case examines the full curve traveled counterclockwise.
  • Participants discuss parametrizing the curves for both cases and explore symmetry arguments to justify that the integral evaluates to zero. There are questions about the correctness of the parametrizations and the implications of symmetry on the integral's value.
Multiple participants have provided insights into the symmetry of the problem, suggesting that the contributions to the integral cancel out. Some have also noted the relationship of the integral to an exact differential, indicating that the integral's value depends solely on the endpoints. However, there is no explicit consensus on the final evaluation, as some participants are still exploring the exact differential and its implications.
There are discussions about the challenges of finding the exact form of the potential function \(\Phi(x,y)\) and concerns about scalar factors affecting the evaluation of the integral. Participants are also questioning the assumptions made regarding the exactness of the differential form.
shoplifter
What is [tex]\int_{\gamma} xy dx + x^2 dy[/tex] in each of the following cases?
1. [tex]\gamma[/tex] is the lower half of the curve [tex]2x^2 + 3y^2 = 8[/tex], traveled from [tex](2,0)[/tex] to [tex](-2,0)[/tex].
2. [tex]\gamma[/tex] is the full curve [tex]2x^2 + 3y^2 = 8[/tex], traveled counterclockwise.
The line integral formula, I suppose. The fact that the integral can be expressed as the dot product of the vector field [tex](xy, x^2)[/tex] with the unit tangent vector to the curve can also be helpful.
I parametrized the curves for (1) and (2) in different ways, viz.
1. [tex]x = t, y = -2\sqrt{\frac{2}{3}\left(1 - \frac{t^2}{4}\right)}[/tex].
2. [tex]x = 2\cos{\theta}, y = 2\sqrt{2/3}\sin{\theta}[/tex].
Then standard integration rules, but I came up with 0 for both the answers. Am I correct?
For no.1, the xy dx part is equal to 0, by symmetry: for every point (x,y) [which contributes xy dx] on the curve, there is another point (-x,y) [which contributes -xy dx] on the opposite side of the y axis. dx is always positive on this curve, so they cancel each other out.
We can also see that the x^2 dy part is equal to 0: because for the first half of the curve, dy is negative, for the second half, dy is positive, while x^2 is positive and mirrored. so the first half cancels out the second half again.So 0 seems right.
2nd question follows easily from the first by splitting it up into 2 integrals: first around the bottom half and then around the top half of the ellipse. We already know from the first question that the bottom half = 0, and by symmetry the top half must be 0 too. 0+0=0.Symmetry arguments are good for checking your work.
I checked your answers and they are correct. Here is a graphical analysis of the problem in both cases:
http://img30.imageshack.us/img30/8343/intego.jpg
AB
So 0 seems right.
A brilliant technical argument, but less mathematical. :wink:
[STRIKE]Note that [tex]d\Phi(x,y)=xydx+x^2dy[/tex] is an exact differential, so the integrals depend only on the endpoints. (I'll leave it to you to find [tex]\Phi(x,y)[/tex].) The second integral is then trivially zero because the start and end points are the same. The first integral is equal to [tex]\Phi(-2,0)-\Phi(2,0)=0[/tex].[/STRIKE]
many thanks, guys! i can't find [tex]\Phi(x)[/tex] though, i keep just missing it by a scalar factor. it would seem that [tex]\Phi = x^2y[/tex] would work, but it just misses it. poincare's lemma doesn't seem to help either. am i missing something obvious? :(
Why does [tex]\Phi(x,y)=x^2y[/tex] not work? You could add on a constant, obviously, but that wouldn't make a difference in evaluating the integral.
oh, i thought because [tex]d(x^2y) = 2xy dx + x^2 dy[/tex]. how do we get rid of the scalar multiple of 2? it isn't an additive constant, right?
Oh, I'm sorry. I misled you. For some reason I thought there was a two there in the original problem. You're right. It's not exact, so you have to do the integral by hand. (And they were both zero when I did them earlier.)
  • · Replies 105 ·
13K
