What is the value of vector a at t=pi given the initial conditions?
The discussion revolves around a vector function a(t) defined in terms of its components a_x(t), a_y(t), and a_z(t). The vector satisfies the differential equation da/dt = j × a, and participants are tasked with showing specific relationships between the derivatives of the components. The original poster seeks to find the value of the vector at t=π given initial conditions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the implications of the equation da/dt = j × a in terms of the vector components. There is discussion about the correctness of the equations to be shown and attempts to clarify the relationships between the derivatives of the components.
Some participants have provided insights into the differentiation of the vector components and the implications of the cross product. There is ongoing exploration of how to derive the second derivatives and clarify the relationships between them, with no explicit consensus reached yet.
Participants are working under the constraints of the problem as stated, including the initial conditions provided for the vector at t=0. There is mention of potential confusion regarding the equations to be shown and the nature of the derivatives involved.
EmmaK
The vector a depends on a parameter t, i.e. [itex]a=a(t)=a_x(t)i +a_y(t)j +a_z(t)k[/itex]..
it satisfies the equation [itex]da/dt= j[/itex][tex]\times[/tex][itex]a[/itex]
show that [itex]d^2a_x/dt^2 =-a_x[/itex] , [itex]da_y/dt=0[/itex] and [itex]d^2a_z/dt^2 =-a_z[/itex].
For the vector a, find its value for t=pi if at t=0 [itex]a(0)=i+j[/itex] and [itex]da/dt(0)=0k[/itex]
[itex]a.b = mod(a)mod(b)cos\theta[/itex]
[itex]a[/itex] X [itex]b = mod(a)mod(b)sin\theta[/tex] [tex]\hat{n}[/tex][/itex]
i have absolutely no idea how to start...
To start you have to figure out what da/dt=jxa means in terms of the components of a, [ax,ay,az]. Can you find the cross product of the vector j with a?
Have you written the second asked-to-be-shown equation correctly? I think it must be modified as follows: [itex]da_y/dt=c[/itex] (c being a constant).
To not get into the trouble of Latex, you can scan a photo of the printed question and put it on the forum.
AB
[itex]da_y/dt=0[/itex] follows from [itex]da/dt= j \times a[/itex]
Oh, yes! I straightly put [itex]d^2a_y/{dt^{2}}=0[/itex] without looking at the first derivative. Thanks...
[itex]j[/itex] X [itex]a[/itex] will be [itex]a_z(t)i+0j-a_x(t).[/itex]
so,
[tex]\stackrel{da_y}{dt}[/tex]=0 , [tex]\stackrel{da_x}{dt}[/tex]=[itex]a_z (t)[/itex] and [tex]\stackrel{da_z}{dt}[/tex]= [itex]-a_x(t)[/itex]
so,
That's a good start. Can you continue from there?
I need to differentiate [itex]a_z (t)[/itex] with respect to t... can i just say it's [itex]-a_x[/itex] ?
EmmaK said:
I need to differentiate [itex]a_z (t)[/itex] with respect to t... can i just say it's [itex]a_z[/itex] ?
Well, no. da_z/dt isn't just a_z. Your last result says it's -a_x. Try looking at the second derivative part. You want to show e.g. d/dt(da_z/dt))=(-a_z). How would that work?
ahh i meant to write 'is it just -a_x'
can you integrate both sides? so da_z/dt is -a_x t , which is a function of t??
a_x isn't a constant. You can't integrate it by multiplying it by t. Just differentiate da_z/dt, that will give you the second derivative, right?
ok...but how do i differentiate -a_x(t) ?
ohhh, it's just -(the x -component of j x a)?
Right. da/dt=jxa tells you how to differentiate the components of a.
