How Does a Linear Transformation T with T^2 = T Affect Vectors in V?
This discussion focuses on the properties of a linear transformation T on a vector space V, specifically when T satisfies the condition T^2 = T. Key conclusions include that the kernel of T is equal to the image of (I - T), and vice versa, as well as the uniqueness of vector decomposition into components from the kernel and image of T. The proofs provided demonstrate that the intersection of the kernel and image of T is trivial, confirming that every vector in V can be uniquely expressed as a sum of elements from these two subspaces.
  • Understanding of linear transformations and their properties
  • Familiarity with kernel and image concepts in linear algebra
  • Knowledge of the identity transformation in vector spaces
  • Ability to manipulate and prove statements involving vector spaces and transformations
  • Study the implications of idempotent linear transformations in vector spaces
  • Learn about the relationship between kernel and image in linear algebra
  • Explore the concept of unique vector decomposition in linear transformations
  • Investigate the properties of the identity transformation and its role in linear mappings
Students and professionals in mathematics, particularly those studying linear algebra, as well as educators looking to deepen their understanding of linear transformations and their properties.
nlews
Hello,
I am working through some examples for revision purposes and am pondering over this question so would appreciate any help I could receive.
I would like to prove that if T is a linear transformation on V such that T^2 = T, and I is the identity transformation on V,
i)Ker(T) = im(I-T) and ker(I-T) =im (T)
ii) kerT n imT = {0}
ii)and that every vEV can be uniquily expressed in the form v=u+w where u E kerT and w E imT
Attempts:
i)
I am unsure how to begin this question.
ii) We know that both ker(T) and ker (T^2) will have the same dimension, therefore it follows that we have equality, kerT = ker(T^2)
Suppose v E Ker(T) n Im(T) then Tv= 0 and so (T^2)v =0, but then w E ker(T^2). Therefore, we have that w E ker T, but then v = T(w) = 0, therefore ker(T)n im(T) = {0}
I think this is quite confused, I cannot see the correct logic but will keep trying to come up with a clearer proof, any help would be good aswell.
iii) Suppose there are u,u' E kerT and w,w' E imT such that v= u+w and v = u'+w'
then these equations imply that u-u'=w-w' E kerT n imT = {0} (from part ii)
Thank you for your help in advance
i) You know that 0 = T - T^2 = T(I-T), so im(I-T) is a subset of ker T. The reverse inclusion is even easier and I'll leave it to you. The proof that I am T = ker(I-T) is quite similar.
ii) Your proof is pretty good, but you neglected to say that w is in V such that Tw = v, so that might be causing a little confusion.
iii) You've given a good proof that every such decomposition is unique, but you haven't said why such a decomposition must exist. To do so, consider the identity I = (I-T)+T.
