Need Help Solving Physics Homework Problem
The discussion revolves around a physics problem involving torque and rotational motion, specifically focusing on calculating torque in relation to a pivot point and the forces acting on a rod at a given angle.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to calculate total torque and equate it to I*alpha but expresses uncertainty about sign conventions and angle measurements. Some participants suggest using the torque formula τ=rFsinθ and emphasize the importance of correctly identifying angles and distances.
Participants are exploring the correct application of torque calculations and discussing potential mistakes in their reasoning. There is an acknowledgment of the need for clarity on signs and angles, with some guidance offered on visualizing the problem through drawing and identifying distances.
There is mention of an attached image containing the question, which may provide additional context that is not fully described in the text. The participants are also grappling with the implications of angle sizes and their effects on calculations.
zhenyazh
hi,
the question is in the image attached.
i just don't get the correct answer.
what i did was count the total torque in respect to the pivot and equal it to i*alfa.
maybe i am getting the signs and direction wrong or maybe i am misplacing the masses.
can some one please write the equation so i could compare?
thanks
You need to find the torque produced when the rod moves through the given angle. Do you know the formula τ=rFsinθ ? (τ=torque)
this is exactly the point.
i know what i should write. but i guess i may be making a mistakes with the minuses or pluses
or with the sizes of angles...
this is why it could be great to see how it should be and from that understand where i was wrong
Draw the rod at the angle of 51.1 and then find the perpendicular distance of the force from the pivot point. Multiply those two and then you can equate that to [itex]I \alpha[/itex]
