| Thread Closed |
Why is a Tungsten filament used in incandescent bulbs? (Factual Question) |
Share Thread | Thread Tools |
| Jan14-10, 08:48 AM | #1 |
Why is a tungsten filament used in incandescent bulbs? I earlier thought that it was due to the high resistivity of tungsten , but i was wrong , the resistivity of tungsten is low at 5.2 * 10^-8 Is it due to its high melting point?? I cant figure out as high melting point doesnt seem to be the only reason for selection of Tungsten. Please Help. Thank You |
| Jan14-10, 08:52 AM | #2 |
Recognitions:
What physical properties do you want from a lamp filament ?
hint - What does Tungsten have the highest of ? |
| Jan14-10, 09:01 AM | #3 |
i think it should be high melting point ( Tungsten has a MP of 3380 C) but again , it has a very low resistivity which means it has a low resistance. So according to Joule's law of heating , a very less amount of heat would be produced . What are your views on this?
| Jan14-10, 09:03 AM | #4 |
Recognitions:
You want less heat - it's wasted energy but that's a secondary point.
The important point is that to get visible light you need the filament to be as hot as possible, an the lamp will fail when the filament melts - so you need the highest melting point material possible (that is also a conductor of course) |
| Jan14-10, 09:28 AM | #5 |
I get it , so the main reason is melting point! Thanks a ton , i have an exam tommorow , this will surely help!
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why is a Tungsten filament used in incandescent bulbs? (Factual Question)
| Resistivity of tungsten filament | Advanced Physics Homework | 3 | ||
| Resistivity of tungsten filament | Introductory Physics Homework | 3 | ||
| Tungsten Filament Emissivity Assistance requested | General Physics | 4 | ||
| Tungsten filament-finding length of coil | Introductory Physics Homework | 1 | ||
| Light bulb filament question | General Physics | 1 | ||
