Resolving Vectors for Electric Charges
The problem involves calculating the electric field strength at a point due to two point charges, specifically examining cases with both positive charges and one positive and one negative charge. The context is rooted in electrostatics and vector resolution.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to resolve vectors into components and apply trigonometric relations. There is uncertainty about which trigonometric functions to use and how to apply them to find the resultant electric field strength.
Some participants are sharing their calculations and comparing results, while others are questioning the accuracy of values used in their computations. There is an ongoing exploration of the mathematical relationships involved in the problem.
Participants are working under the constraints of homework rules, which may limit the amount of guidance provided. There is also mention of discrepancies in calculated values, indicating potential confusion or miscalculations in the application of the formula.
physicsfun_12
Hi there, I am having a lot of trouble with this problem. Any help much appriciated.
Thanks inadvance.
Two point charges, each of 4x10-6C are placed 1m away at points A and B respectively. Calculate the electric field strength at a point P, which is a distance of 1m from both A and B in the cases when:
i) both charges are positive
ii) one is positive and one is negative
E=kQ/r2
Ok well I know that I need to work out a resultant, however I am not sure whether to use sin or cos, and even then how to use them to get the correct answer!
Thanks again for any input
Mike
When you separate a single vector into two perpendicular components, the three lines form a triangle, yes? Then you can easily apply your trigonometric relations easily with reference to the diagram. E sin theta would give the component opposite to the angle, while E cos theta gives the component adjacent to the angle used.
Oh I see, so since the x components would cancel, you would just double the y component which is cos30*the elctric field strength calculated
i.e. 6.28104NC-1
Thanks a lot, do you know if the answer I have calculated is correct?
That's for part i) I presume?
My answer appears to differ from yours from the 3rd significant digit; what value are you using for k?
Hello, I used 8.99x109 for k.
Thanks again!
Mike
Hmm...press your calculator again, you appear to have read some digits wrongly in the answer you provided above.
You are quite right!
I got 6.2284x104 this time!
  • · Replies 22 ·
