Motion at Constant Acceleration Question 2
The problem involves determining the length of a runway required for a light plane to reach a takeoff speed of 33 m/s under constant acceleration of 3.0 m/s². The context is rooted in kinematics.
  • Participants discuss the use of kinematic equations to relate final velocity, initial velocity, acceleration, and displacement. There is uncertainty about which equation to apply and how to manipulate it to find the required distance.
Some participants have attempted to identify relevant kinematic equations, while others express confusion about the initial steps. Guidance has been offered regarding the relationship between the quantities involved, but no consensus on a complete solution has been reached.
There is a noted confusion regarding the units of the final answer, with participants clarifying the distinction between meters and meters per second.
Adrianna
A light plane must reach a speed of 33 m/s for takeoff. How long a runway is needed if the (constant) acceleration is 3.0m/s^2?
I looked at the Kinematics Equations and tried to re-arrange them to be able to find the distance with what I was given.
I am not sure how to start it, this is always my problem I can't seem to figure out what formula to use.
You have a final velocity, an initial velocity (the plane should be at rest) and an acceleration. You want to find a displacement.
Which of the kinematic equation contains those 4 quantities?
vf^2 = Vi^2 +2ad...?
So when you use that, what do you get for 'd'?
v^2 = 0 * 2as
where v is final velocity, a is acceleration and s is the distance
I got 1.8 m/s and that's the right answer thanks so much for the help
you mean you got 1.8m. m/s are the units for velocity.
  • · Replies 16 ·
15K
